Their name is very descriptive of character of their sound, that's why many don't care for them!
david
+1
david
Boulder amps are one of those oddities in that they just don't get much respect in some audiophile circles. However, it should be noted that according to Boulder, all of their behemoth amps are optimally designed to work with 220V and NOT 110V as most of you have commonly heard them. Believe me, the difference is astonishing. I heard this effect from an AC line voltage change on Brian Flowers' Alexandria based system back in DFW a few years ago (with the 2060) and was astounded at the difference.(...)
Probably the problem was with the 110V mains power line. 220V requires half the current, so the relative voltage drop will be half. Another possibility is that the amplifier has a very poor mains noise rejection and the 220V balanced supply cleans it, but I find difficult that such an high quality amplifier suffers from such problems.
Just have a few moments and wanted to jot down some quick thoughts. As many of you are aware, I recently built a new audio room. I spent over a year listening to every high end system and component that I could. I ended up selecting the Boulder 2110/3060 combo. We all have different priorities, but for me these were preferred. These seem to pull everything off of the recording that is there. Once you have heard that, it's hard to hear less. The challenge with Boulder is that they don't have much of a sound of their own. This, combined with incredible transparency can make it very difficult and frustrating to get things just right. The reviewers kind of get it right when they point out that one can easily hear an outlet change, cable change, etc. It took me a couple of years to get my old 2010/2060 set up just right. Had I not accomplished that, I'm not sure I would have gone that route again. But, I can see how someone could listen to a boulder system that hasn't been completely sorted out, and think it didn't sound very good.
I have a 2110/3060 combo as well, and there is also an advantage in terms of lower distortion with using 220 for the preamp.
So I had the electrician run separate dedicated 220 lines for both the preamplifier and amplifier.
Thanks for the welcoming!!! NAS into Mac Mini running Roon, Boulder 2120 DAC, 2110 preamp, 3060 amp, Magico M Pro speakers, Critical Mass Maxxum stands, Nordost Odin 2 cables and power cords. Would love to add analog too just haven’t taken that step. The system is in a room designed by an audio engineer with absorptive walls (couple reflective points by design, but almost all panels absorb sound) that pulls double duty as my home theater. So one of the 2110 inputs is a Kaleidescape Strato 4K Ultra HD movie player into Datasat rs20i into Sony 4K projector.
