Someone tested the Lyra phono cable?
Jonathan, you use the FR 64 with the Lyra? Silver wire? Any other tweaks?
Shane, I acknowledge that you may have simply preferred the Nordost. That said, did you try increasing the phono stage input resistor value when you used the PhonoPipe? The extremely low capacitance cable structure (32pF for 1.2m) was designed primarily to facilitate the use of less loading on the cartridge.
These days we are using the SAT, which has a captive tonearm cable.
But for any tonearm that uses the universal headshell system (including the FRs), the headshell contacts and wiring are a decided weak point.
The sound quality can be improved by providing each headshell with a dedicated wiring harness that is long enough to reach the phono stage, and made of thin Litz (or magnet) wire so that the tonearm motion is not impeded. Gently twist the plus and minus wires together, enough to avoid picking up noise or hum, but not so much that the harness stiffens and impedes the motion of the tonearm.
The wires should be secured at one or two locations along the tonearm tube, and another at the rear panel of the turntable plinth. Do make sure that the wiring harness is generous around the tonearm bearing - coiling it, arching it over the bearing, securing it to a "V" shaped recess directly above the bearing should all be suitable. The harness can be terminated in RCAs or XLRs, whatever is appropriate for your phono stage.
If you attach a small Velcro wrap around the arm tube, and a second Velcro strip or some kind of clip at the plinth rear panel, you should be able to secure and release the wiring harness quickly and easily.
When you remove the headshell, its wiring harness goes with it, therefore you will need a storage location with sufficient room to accommodate and protect both headshell and harness.
BTW, it may be safer to leave only the ground lead portion of a ready-made tonearm cable connected to the phono stage, this is to keep the tonearm grounded and prevent hum or electrostatic issues.
Mechanically the universal headshell socket again leaves much to be desired (even when using 2-pin headshells), but simply cleaning up the electrical system should deliver a rewarding upgrade to the sound.
Hi GianSomeone tested the Lyra phono cable?
Hi KedHave you tried the Lyra on the ortofon arm? How is that?
I loaded the phono higher at 1k. Sounded better, but yes I still preferred the Nordost.
Wonderful cartridge, although for the first 20 hours I thought I may have made a mistake getting my Atlas rebuilt as a SL)
the micro dynamics are not as lively as the non SL
I guess that is why you recommend lots of gain for the SL series - i use at 70db vs 60 for the non SL.
For me, Atlas SL is top dog![]()
Thank you so much for showing technique.
waiting to try your new step up.
I am a fan of your carts...having AtlasSL and Etna Mono.
This thread is starting to gnaw at me. I'm running a DV XV1T which I love, an upgrade from a Kleos SL. I enjoy the improved dynamics and treble response. What would the Etna(SL) or Atlas(SL) bring to the party over the DV? Thanks.
