Looking for a recommendation where to buy the NCF wall outlet kit. I just need one duplex ncf Outlet, the mounting plate and the CF cover. TIA
Joe Pittman from Kosmic Audio is a WBF member and my Furutech dealer and sold me all mine (and installed them too). he is very knowledgeable and stays up with all the latest stuff like this. he also retrofitted all my Absolute Fidelity power cables, and Evolution Acoustics power cables, with NCF plugs.
http://www.kosmic.us/
DaveC, our member who sells cables, is also a Furutech dealer.
btw; send David K. an NCF IEC receptacle to be installed in your American Sounds controller. it will sound better. you want his builder to install it to prevent any issue going forward.
Furutec has the new NFC Connector Cable Holder out. You and Christian might want to be the first squad to try. I can follow later if you dont walkout bleeding.
Tang
ZenWave Audio. I had Dave replaced all the IECs and outlets on 3 power distributors with NCFs.Looking for a recommendation where to buy the NCF wall outlet kit. I just need one duplex ncf Outlet, the mounting plate and the CF cover. TIA
What's the retail on the booster please ?
NCF booster:
http://www.furutech.com/2017/09/29/15585/
I have not tried it out yet but expect the results to exceed my expectations if it's anything like the rest of the NCF parts.
Furutech also has a new, very advanced power cable that competes with cables at any price when terminated with NCF plugs. It's $450/m so not cheap but much less than many other high end PCs. I am offering the best deal out there on terminated DPS-4 cables...
http://www.furutech.com/2017/05/10/14783/
http://www.audiocircle.com/index.php?topic=152433.0
I've been experimenting with a single DPS-4 power cord on my VTL 7.5 III preamp and am impressed thus far. As we know, the cord itself is but one part of the PC equation. The other part is the connectors that are used on each end. Along this line of thinking, I have found that what the PC is plugged into at each end may also be important in determining the optimum connector to use. In fact, the ideal connectors just might be different at each end of the PC. Some of my rationalization regarding the choice of connectors at each end can be found here:
http://www.whatsbestforum.com/showthread.php?23376-Fun-with-Metallurgy&highlight=metallurgy
While the experiments above led me to conclude that my preference for AC outlets was copper base metal with no plating, a recent experience at Gian's (Gian60) in Italy this past summer contributed as well to my current thinking., I was truly impressed when I heard Gian's system and learned that his power cords, made for him by a friend, used Furutech's FI-11 pure copper male connectors rather than one's plated with gold or rhodium (which I eschew). It's always difficult to attribute the sound of something to a particular component in a system that one is hearing for the first time, but there was something about the purity and naturalness of Gian's power delivery that made me think I should explore those FI-11 connectors at some point.
That's exactly what I've done with the DPS-4. For now, the FI-11 male connector with that cable has provided sonic results that are superior to everything else I've tried with the DPS-4. Keep in mind that's its work in progress as I am still exploring what might be the optimum metal to use on the IEC connector, which couples to a gold plated connector in my preamp as opposed to a copper AC receptacle. Hence, I'm exploring the FI-11 female connector (which is phosphobronze and not pure copper), and assorted other connectors such as the Oyaide 004 (copper/platinum/palladium) and Furutech FI-28 (copper/gold). But for now, I think I've got the male plug side of the equation solved with the pure copper FI-11 thanks to hearing it in Gian's system. BTW, this is also the least expensive of the Furutech plug line!
Nice, good info! I offer the FPX(Cu) receptacle, which is unplated phosphor bronze, as a budget option and I like it better vs any of the "hospital grade" units. I can see the FI-11M working out well being pure copper instead of bronze but you'll have to use something to prevent corrosion like Caig progold or Furutech nano-fluid which will change the sound a bit. I've tried periodic cleaning of unplated plugs on some other non-audio appliances with poor results... once the surface has tarnished it comes back way faster the next time since the surface isn't as resistant anymore. But if you find a something you like to protect the metal and apply it every 6 mo or so you could keep the plug from corroding. I'd hesitate to offer the plug on my cables as I can't be sure the owner of the cable will maintain the metal properly and once it's tarnished it's basically ruined as the surface will never be the same again. OTOH, hospital grade receptacles will quickly scratch through plating on male plugs anyways, so if someone uses these receptacles it will always be a problem as they mar the surface of the plug which will encourage corrosion. This is one plus for rhodium, it's a harder material vs gold and won't wear down as quickly. I still think you should try the NCF plugs though, they are the most neutral plugs I've tried by far.![]()
