I am going to run some AC wires from my breaker panel to my Hi-Fi rig. Any recommendation of good AC wire?
Yes, but it doesn't need to be a sub-panel, it can be a simple 6 breaker box.If it's a longer run definitely go with a sub-panel as close to the system as possible and run 10g wire from there.
Exactly!The idea is to lower resistance as much as possible between component grounds. This will absolutely increase sound quality by lowering noise.
Now most hi-fi systems should be on a single 120V, 20 A circuit.
But if it's a very large system that needs more power, I would run a large 120V feeder from the main breaker panel to a small breaker box in/near the audio room.
The idea is to reduce the length of AC cables from hi-fi component to component.
Thanks guys for all suggestions. It is going to be a short run around 5m. Further question, will unequal length of in wall cables cause ground noise?
Sorry, I don't have access to any of the now available models, to open up and examine.If the Hi-Fi system in a single circuit, what power strip would you recommend?
a] I don't know just where the equal length power line idea came from, but engineer's that should know better repeated it.
b] Yes, run a the power cables on the same path, close to each other.
c] Examine the breaker box (panel board) and make sure that all the hi-fi circuits are on the same pole/leg (aka phase).
d] SurgeX's are great but very expensive. For most people a whole home surge protector near the main breaker box is all you need.
Seldom do Dave and I agree on even 3 out of 4 points.
Going back to point [d] MOV point of use surge protectors are not a good idea.
Hello,
Regarding point a. above. The lengths of the various runs need to be the same so that the ground impendance of each leg is the same. If the impedance are different you will create a ground loop and get nasty hum. I fell into this trap and paid dearly for it. So each "in-wall" line needs to be the same length. You can snake the extra back and forth in the attic or wall or whatever. Do not coil it up or you will create a lot of inductance in the line.
Hello,
