I bought a A95 and Sunday morning I will put on my Bergmann Sindre
I am curios to listen and do comparison with my Coralstone Diamond,GFS and Opus 1
What do you think Ked,
i can change Ortofon AS 309 S with SAT with Tango?
In the future, just for fun we can do a trans continent cartridges loan. I also just bought an Anna.
Kind regards,
Tang
I like my MC Anna. It doesn't get much play time however as I prefer the ZYX UNIverse Premium so much better
Steve, Could you briefly highlight the sounds signature difference between the two? What are they both mounted on currently?
Thanks
howie
Steve, couple of quick questions about the Zyx and the Anna. What loading are you using for both and what do you find is the difference in output between the two? As to output, apparently the Zyx puts out more output than the Anna...although the specs don't really seem to bare this out. If that is the case, do you have to increase the gain at the phono stage with the Anna in place to match the gain when using the Zyx?
IMO there is just no comparison
The Anna is very nice but seems "polite" when compared to the ZYX. With my phono stage (Lamm LP1 Signature) there is no loading. There are 2 MC inputs. MC1 uses a SUT for low output carts and the MC2 input uses an SUT for a standard output cartridge. What I had Vkladimir do is to put the same normal output SUT in both inputs as it is most unlikely I will ever use a super low output cartridge
I agree that comparison is not valid as my ZYX is mounted on an SME 3012R arm and the MC Anna is on a 10.5" Graham Phantom Elite but everyone who has heard the two in my system prefer the ZYX Premium
Do you have to apply a lot of gain on your LP1 with the Anna...more so than the Zyx?
BTW, I understand loading the Anna at 500ohms can bring some very nice results...may want to look into adding loading plugs upline of the input to the LP1.. Vladimir should be able to help with that.
Might even benefit the Zyx?? I have noticed that getting the loading correct with MC's can seriously improve the sound. Just a thought
Yes
not interestested Davey as IMO the LP1 is about as perfect as a phono stage can get. No way I want to fiddle with what I consider to be perfect
+1
A95 + Lamm match made in heaven
