what would YOU choose over Artisan Fidelity?
Personally, I would be looking at the AF Technics Sp10Mk3 NGS or the Wave Kinetics. For those $$, try to visit each dealer and listen for yourself.
Both have the ability to have any tonearms you like, which is ultra important at this level.
I heard that Technics with the Airtight Opus at Munich. Tough to say anything about what it sounded like though, but had bass.
I think the bass is due also to Opus.
I never listen a cartridge in my life with the bass like Opus,very full powerful,clean
Just sharing my experience, I have directly compared a basic Rockport Capella II (ruby bearing, non-vacuum platter) with the 6000 airbearing arm, to a highly modified slate plinth Lenco with PTP 5 kit and Jeremy’s bearing (so pretty close to the PTP Solid 12 mentioned by Marc), and the Terminator airbearing arm.
On macro dynamics alone, the modified Lenco really had the upper hand, and it seemed to have even better macro dynamic than direct drive like the Exclusive P3a. The only direct drive that I have auditioned that could rival the modified Lenco on this area maybe the Technics SP10MK3 (but I have not done any direct comparison between them).
However, what it lags behind, as compared to other high grade belt drives and direct drives, are the finesse, micro dynamics, sound staging and layering of instruments within the sound stage. That could be due to the unavoidable higher vibration transfer from idler drive.
To answer Peter’s question, in my experience, the modified Lenco had very good bass quantity, but not quality.
thekong, Thank you for answering my question. Your post agrees with my contention that it has more to do with specific design implementation than it does with drive typology. We have not discussed bass extension or impact as opposed to quantity and quality. IMO, if bass is of good quality, all the rest seems to be right, ie real or natural, lifelike in terms of extension, impact, texture, color etc. "Quantity" implies to me big, full, loud, as in amount of bass. Perhaps the OP can clarify his goals.
Hello again Peter
In my own muddled way I was trying to communicate what sort of bass I'm seeking by invoking a 25k sound system in a large warehouse playing drum and bass at war volume to a few thousand people.
If you're unfamiliar with the experience and genre, the best way to describe the challenge to a system is to imagine a huge natural amphitheatre filled with blue- painted, iron - age nutjobs tranced out on magic mushrooms and beating a multitude of drums,
while at the back some lunatic is banging two planets together.
This would be the effect I'm going for..
Hullooo XV-1
The problem is that to audition either would involve transatlantic travel...which as a cannabis user is something I'm truly not a big fan of. If it were to visit Boulder that might not be an issue...but AF are based in the mid west, if I recall?
EMT is a consideration
If you are considering the Garrard 301, a great arm/cartridge combination to consider is the EMT 997 tonearm and EMT JSD s75 cartridge.
I did have a chat with Chris at Artisan Fidelity about EMT turntables.
If I remember correctly he felt that the 927 was the one to go for.
And also that going down that route might not leave much change from $60k...so for me the AF Technics sp10 ngs might be the way to go
Yes my apologies you're referring to EMT arm and cartridge
My intention, whichever tt I choose, is to buy a complete package including arm and cartridge in order to avoid compatibility issues
Emt
If Artisan can drill and mount the EMT arm you should have no problem. Regardless of the arm, based on your comments about the sound you like, you should listen to an EMT JSD s75 or other similar cartridge. It has the powerful bass you are looking for as well as defined highs. The Garrard 301 plays big sound and so does an EMT cartridge.
rim drives have great bass, no doubt due to massive torque
sounds like you will need a plinth that can accommodate multiple arms
AF111 will allow multiple arms at expense
direct drives also have good bass
you could get a technics sp10 and plinth made which will accept multiple arms
if you want thundering bass get this :- photo-2.JPG
Hullooo XV-1
You could always buy a fully functional Technics SL1000 mk3 for less than the 10K credit you would receive if you had a SP10Mk3 donor for Artisan.
http://www.ebay.com.au/itm/Technics...033263?hash=item41c94b5b6f:g:nd8AAOSwwzhZTKXb
This way you can listen to it as designed - even put a new tonearm onto it like i have done - then trade it to Artisan for 10K if you wanted the Artisan treatment.
cheers
That's really helpful, I will look into it.
Thank you very much ?
if you want thundering bass get this :- View attachment 33621
That's very helpful, thank you.
I see you also use Stealth cables. Can I ask which variety?
I was told the Metacarbon is especially good for bass.
Speaking of, is that five subwoofers you are using, and any chance of a pic? :cool:
cheers
Interesting concept...
As an aside, I've just become very distracted looking at vintage Technics gear.
Like this:
ztHDx5
As an TechDas AF1 and a Clearaudio Master Innovation owner... if I wwere to add a third TT, it would be an Artisan Fidelity Technics SP Sp10Mk3.
Reactions: Bodhi
That's really interesting...can I ask what you feel it would bring to the table
(pun not intended)
compared to your other turntables?
For me...it's the direct drive option. Both of my current tables are belt driven. This is the table I would buy if I were in the mood and wanted to spend the money.
https://www.audiogon.com/listings/t...142156862855&gclid=CIvkx7GU69QCFcGGaQodFsIOHw
Yes I think the same turntable /arm /cartridge combination will most likely be my next major purchase.
I prefer the jade finish of the 501 statement on the AF website, and might succumb to the fashion for two arms
Hi guys
If you had a friend who was considering pulling the trigger on either an Artisan Fidelity 301 Statement or AF Technics Sp10Mk3 NGS, (or both), what would be your advice?
Would you steer them towards Kronos, Techdas or someone else?
I liked what I was hearing about Wave Kinetics decks, but was slightly put off by the lack of any dealers on my side of the pond.
Who else should be on my shortlist?
My listening material is predominantly bass-driven electronica with a side order of acoustic. So deep hard banging and gospel house, drum and bass, roots rockers reggae and dub with a bit of Alt - j and James Blake. It needs to sound huge, powerful but also delicate and musical. Bass extension and soundstaging are a close second to musicality on my wishlist. I don't like overly faffy record changing rituals, the two stage screw down clamp of my Avid was a no- no, and I plan to have at least two decks in order to keep the musical flow going.
Current phono stage is a Boulder 1008, I missed the last 2008 by about a fortnight and will upgrade to the 2108 once it is released. With four arms on two decks another phonostage will be required tbd.
Support is an Artesania Esoteric rack with tt shelf.
My plan is to go with dual armboards so I can optimise one arm and cartridge for dance music and the other for acoustic.
If I do go AF the mooted arm cartridge combos are:
Sp10Mk3 NGS - Kuzma 4Point / Miyabi Fuuga for dance music
-Schroeder CB-1 / Miyajima Madake for acoustic
301 Statement - Ikeda 407 / Fuuga
- Schroeder CB-1 / VanDenHul Colibri XGW
Any opinions will be greatly appreciated
Thank you very much
luvgav
You're choice of deck spans many types - Belts/DD/Idler - arguably a laudable approach because it is application, not type so to speak. If you have the money consider the Saskia Idler, if you can source one a Micro Seiki (there's a brilliant thread about them).
the Audio Note reference (3 motor belt drive) is supposed to be a step forward from the wonderful Voyd Reference and to my ears at least seemed to be the closest to 'all things to all men'
What country are you in my friend?
I'm in the uk :)
The Voyd was the stuff of legend when I was going through the ranks.
I'm not familiar with the Saskia , I'll do some research.
Thank you for your input
