Alexia V2 on order along with a few D'ag Momentums
Enatai252
163
23
150
Pacific NW
I have been working with my local dealer on whether I wanted to move up from my current Alexia V1 pair to the Alexx. The current system sounds so dialed in to me I had a real hard time pulling the trigger on the bigger more complicated Alexx (and I never fell in love with the Alexx look). I will say the Alexx is an incredible speaker and I don't doubt it can outperform the Alexia...just was not for me. Well when the new Alexia V2 was announced ( upgraded tweeter, more adjustability, more internal volume and easier to drive) I decided that the way to go was with the new V2 rather than Alexx so order went in (unfortunately there are a lot of orders in so not being delivered till late in July)
At the same time I have continually been listening to and really enjoying the D'ag Momentums. My current system has 3 MXR 20's and a VXR 20. They are awesome amps and as I mentioned above my system - as currently set up - has never sounded so dialed in...but a recent tweek to put the amps on HRS M3 platforms and HRX amp stands along with vortex supports proved to me I can get more out of it. So along with the new speakers...I am getting 3 M400s and a S250 (black versions) along with moving to TA Ref gen 5 cabling. I am keeping the Ayre amps as they are too good to sell....will be considering where to insert in other current systems (swapping out my VX5 twenty in my study for the VXR twenty is a given) or to set up one more smaller system
I am going to keep KXR twenty as the preamp with sources being dCS Vivaldi stack, Linn LP12/Ref2SE, Naim CD555 and the Datasat R20i processor
Alidas and Mezzo CST are the rear and center speakers
Will be awhile before all put together but look forward to pushing the performance just a little bit farther
Congrats on the audacious moves! Look forward to photos and comments...what is the timing for everything...all arriving in July? or will you get the amps and TA cables sooner?
I expect the cables to come quickest, then the amps and lastly the speakers so I plan to enjoy a step by step journey to the eventual full upgrade
Wow, congrats ! I've always liked the Wilson Alexia / Dag Momentum combination.
great stuff...enjoy! Pls comment when you can about the arrival/installation of each piece. Should be good fun.
Congratulations on the new purchases. I noticed with the HRS rack and stands when I obtained mine was that it does indeed lower the noise floor of your system allowing more detail and music to come through. I am curious as how you will react when the system is fully changed and tweaked with the new TA Gen 5 cables. You are going to be very happy I think?
Nice choice with the amps. I have heard the MXR in my system and the Dag is a class above.
You will love the new grar.
Congratulations! My favorite pairing with Wilsons is DAG. I've been enjoying my Alexias with DAG for the past several years. The S250 and the M400s make the Alexias sing beautifully.
Can't wait to hear the V2s.
Congratulations. IMHO buying Alexia S2's will deservedly generate a lot of congratulation mails, just on the fame of the old Alexia!
I sometimes say that if I was a reasonable audiophile I would still own the Alexia's - if we weight all factors such as cost, performance, versatility, space and sensitivity the Alexia is really a winner.
Congratulations, I used to own MXR's and Wilson Maxx 3's. I can understand your fondness for that combo...I've heard the D'ags as well...know you'll be quite happy !
Since you're a Transparent Cable owner...have you tried their latest gen power cords? The Opus Power Isolators/cords on my Vivaldi stack and pre/phono are quite special ...
The amps and cabling are in. Have them warming up this morning and will allow some time to settle in before sitting down to listen. Two things I did confirm as we installed them. They are heavy for their size and they are gorgeous.
The Ayre VXR 20 went to the study to be matched with a Rossini DAC. Two of the MXR 20s going to my cabin to spend time with Duette2 and Ref 40 system
As system comes together I will provide comments. I really liked where the old system had gotten to so the bar has been set high
Jfrech
First congrats on the system you have pulled together over the last few years including your room....just amazing
I use Audience products for non amp components and connect amps directly into dedicated 20 amp circuits. Have not spent too much time on power cords. I like the Naim Power lines and use those for most components
Perhaps that is a journey in the not too distant future but not a priority for now
Did you buy replacement HRS stands for the Momentums or just rebuild the ones for the MX-Rs with new feet?
(...) The Ayre VXR 20 went to the study to be matched with a Rossini DAC. Two of the MXR 20s going to my cabin to spend time with Duette2 and Ref 40 system
What are the main differences in sound quality between the MXR20's and the Momentum´s?
When I recently bought the M3X bases and SXR stands I had them custom ordered to fit the MXR or M400 amps which have very similar exterior dimensions. Each amp sits on four vortex pods. The M3X bases configured for the Ayre MXR had green footers in front and red in back. For the M400s, we initially had four blue footers but after working with HRS and measuring compression we are going with four green. Unfortunately my dealer had brought all blue footers so we moved the two green feet to the back and added two blue on front.....when the new greens arrive I am going to swap out the fronts
I am going to give the amps and cables some time before I draw any conclusions. My expectation is I will see most improvement in the lower registers along with a little more definition, micro details and spacial cues in the mids and upper registers
I think the only difference between the MXR and M400 stands is an inch or two in the l and the w and the feet. Both units will fit fine on the other's base. HRS told me the same thing regarding four greens which was weird but they said the new greens have a lot more something or other compared to the old greens and should be used for the M400s instead of the blues.
Have you tried the vortex in place of the Nimbus couplers. They work well on both the MXR and M400s
Did you directly compare? On the MXR and the M400?
Haven't had a chance myself (also not in love with the chrome - hoping there will be a black option like the nimbus).
