Perhaps in future MQA software decoders there will be a drop-down list of DACs to choose from so that the software can perform the needed "time corrections" for your particular non-MQA DAC. Then you should get the full MQA sound-quality potential.
While I'm a Windows PC user, I believe I can be of some assistance. Currently the "Masters" heading to access MQA albums is only shown on the Tidal desktop app which is available at http://tidal.com/us/download . Once you download and install the Mac version of the software, login and you should then see the Masters heading within the Tidal app (you may have to scroll down to the second row of headings to see it.) Once you select it and "view all" you should be able to see the MQA albums displayed. If you then mark any albums you wish to hear as a favorite by clicking on the star icon within the album cover those selections will then show up as favorite albums under My Music in whatever other app you use while logged into your account (i.e. via Chrome, or another product specific app with access to Tidal.) Hope this helps, let us know either way. In time the Masters should become directly available in other apps, and Tidal should somehow visually designate MQA albums to differentiate them from other versions. MQA albums should also be made searchable by tagging a chosen field to uniquely identify them.For the life of me I cannot get this page. Downloaded Google Chrome, Adobe Flash, already pay Tidal $20 a month, emailed (only way of freekin communication) them for help and still get no "Masters". I click on "What's New" and only get recent releases (Featured). And click "Albums" and get only my albums. This on my MacBook Pro.
Have you installed the desktop app? You won't get the Masters otherwise (unless you have an MQA DAC).
Thanks and yes I have. Tidal help is of no help. I have downloaded Tidal app 3x to no avail.
I had a similar problem and succeeded by going to tidal.com and downloading the Desktop version and not the version from the App Store which may be the iOS version.
So, to get MQA without the unfolding but at least a 24bit version you add the album to your library as has been mentioned. It then shows up on your iPad within Roon, for me at least, and I can then play the 24 bit version rather than the 16 bit version. Only trouble is most of the titles are not interesting to me ie. Fleetwood Mac or Phil Colin's.
The few that are I already have as hi res downloads.
Good luck with your endeavours.
Blue58
The app for OSX is what I downloaded to no avail.Please note. When we say the Tidal ap we are not talking about the one for your phone or iPad. There is a Tidal Ap for both Windows and OSX computers. You download this from the Tidal website. This is the one that you need to use for MQA.
The app for OSX is what I downloaded to no avail.![]()
And just for completeness, you are a Hifi subscriber, right?The app for OSX is what I downloaded to no avail.![]()
Yes, of course. And now I have 4 Tidal downloads from PC+MAC. And this on the bottom:
* Currently lossless streaming with our Web player is supported in Chrome only,
** Currently TIDAL Masters audio is supported via our desktop application only.
Sorry, I have seen that notation but it is not applicable for my application as I am using a MQA capable DAC.
Does it matter what DAC one is using with a MacBook Pro? I am downloading Tidal from my MBP.
^ My point is I can't even access the Masters section. It just is not there after, before, during any and all the downloads. When I select "Whats New" it is not even remotely seen/there.
it really sounds as if you aren't seeing (using) the desktop app. What you describe is what I see when I just log in to tidal.com, not when I use the app.
You are right. It was in my app. folder, but I did not double click it to download. Thanks everyone for your help!
Now to figure out using MQA with my Audivarna+
..it'll work with A+3.0. Wait till June. .
On another issue: you and I both had wadia s7i, not sure if yours was also gnsc like mine. Do you ever miss it?
