Here is something to add to this. It's Rane's excellent Tech Note about system grounding and the differing combinations possible. It is also well understood the problem is no industry standard. I have 4 systems currently operating and hands down the quietest of the 4 is the completely balanced system. Not saying the others are excessively noisy but any system I have to put my ear at the edge of a midrange horn to hear any noise at all is darn good!
Rob
I think that the Transparent Power Isolator MM Power Conditioner is not an isolation transformer - as far as I could understand it isolates only RF. The PIMM with a set of Transparent Power Link MMs sounded great in my system - unfortunately wiring it all with these cables would cost a fortune and I had to let them go.
The tests were carried with the conrad johnson Premier 350 - a good friend of mine was so impressed that he bought this unit and cable for his Premier 350.
AC leakage is not only 50/60 Hz - it is also a lot of noise. It is one of the reasons why many transformers have a screen connected to the ground between primary and secondary.
A good isolation transformer is definitely a great way to reduce Leakage Currents.
This one is huge, but most setups can get back using smaller ones. If you do go this route though, it is important to find an isolation transformer that would contribute little to parasitics. That means looking for one where the stated inter-winding capacitance is really low.
Now we are cooling with oil! Dan, I want to be in your camp! Let me know if there are any hazing rituals I need to go through first.
Lol,
You hit 2 at once .
Free flow for electrons, plus mass loaded resonance control.
I remember a plant i worked , there they didnt lock a big roll up with large diameter copper cable
They use to cut off a meter day until it was empty , and stripped IT and delivered IT to a metalscrap at then 5 euro a kg copper price
DDK and MikeL use single-ended interconnects.
Jim White -- can there be any serious question whether Jim is qualified to opine on the sonic results of the Io -- I believe prefers the balanced connections on the Io. Vladimir Lamm obviously believes in single-ended. Flemming advocates balanced connections.
The argument that single-ended should not be used for long interconnect runs because you have a small amount of voltage drop seems silly since one can simply raise a volume control a litte bit to compensate.
The view that balanced connections cancel even-order harmonics but not odd-order harmonics seems more damaging, if this is true. Is this true?
In conclusion, we have another important topic which is clear as mud!
Don gave the precise and exact answer. But to expand, the drop in voltage we worry about here is in the shield of the RCA/unbalanced connection. That drop in voltage will by definition cause a flow of current (it is like titling a full cup of water). Since the source of that voltage is mains, the shield is now dancing up and down with the frequency and harmonics of mains.The argument that single-ended should not be used for long interconnect runs because you have a small amount of voltage drop seems silly since one can simply raise a volume control a litte bit to compensate.
No, I am actually completely staying away from the internal architecture of an amplifier. All we are discussing is how audio is transmitted between two pieces of audio equipment. This can and is routinely implemented in balanced mode regardless of whether the amplifier itself is single ended or balanced.Amir is what you saying is that THD is proven to be lower on balanced amplification versus single ended amplification??
