Awesome stuffPlease keep us updated.
I will be able to provide an update in a few days since I ordered one yesterday evening. Can't wait to test this out in combination with the new JCat femto usb card.
where are people buying the KR242 tube ? These are used in my second and third gain stages in my Allnic H5000 phono. I am interested in pricing from whoever is selling them.
check the pin configuration of your Alnic compared to the 300b configuration on for the Lampi.
I have a 20 year old NOS set of KR242's that needs an adapter to fit into the 300b pattern. make sure your Alnic uses the 300b config.
Allnic uses a different pinout...not the 4 pin base used in the Lampi.KR242 tubes are standard equipment on my Allnic phono. I was just curious where people were buying them, since they are for OEM from what I understand and are not available by the usual tube retailers.
Mike L has a pair of the older type.
My KR242 are 4 pin in my Allnic.
old and new are both 4 pin, just slightly different. one won't work in the other......they will break trying to insert them.
likely my older KR242's are the pin config you need. they are different. the question should be whether the Alnic uses the standard 300b config. if not, then these new ones won't work without an adapter.
make sure you check it out before buying these Lampi versions.
btw; i'll sell you my old ones, as I got the new ones from Lampi. PM me if interested. I paid a pretty penny for them and have the adapters for the 300b pin config. but I only used them for 10 minutes since the gain was wrong.
Would like to find a pair KR 242. I will eventually order from Kron, but maybe someone is sitting on a pair and not using them.
Trades are possible too, px25 I.e.
You can try out mine. I am not selling, but if you want to check if they work in your system, I will tell Christoph to post mine to you (he is currently trying them out) and you can post back.
If you were hard pressed, only to have the KR242 OR the EML 45 mesh anni globes, which ones would you choose?
Wow, thanks for your generous offer. My GG will go back to Poland this Saturday and it will come back with the 242 setting, even now my GG does have the 242 setting. It shouldn't be a question whether they work in the GG, but just how well they work.
In other words, it'll probably be three weeks before I have the GG back.
I think I'd rather buy a pair and complete my collection. -)
