What model of iPad or iPod are people using with their Vivaldi's?
a iPad mini...
a iPad mini...
I use an iPad Air.
Jfrech-did you get the 2.0 umpsampler upgrade yet. If so....thoughts?
I get mine just before Labor Day
Not yet. Hoping in the next 2 weeks ... Looking forward to it for sure ...
My VUP went back yesterday. Should have it upgraded by end of next week...
I think you will be very happy. I have about 2 weeks on mine. It may take some time to adapt to the new app UI....I have the Rossini so was already working with it. Music streamed via Ethernet from my server improved in terms of resolution and what I call presence. Performers gained more definition and I feel like the I receive more spatial clues from the recording venue especially from live jazz or acoustic selections. So far I believe the DAC 2.0 was still bigger improvement but the upsampler plus is well worth the cost and time to upgrade. Listening to lots of piano, female acoustic and Horns (Coltrane and Miles). Incredible
As a sad note to spoil my enjoyment I am still unsuccessfully trying to install minimserver in the Synology 416J ...![]()
Listening to Gerry Mulligan, "What is there to say" Redbook, F5 off the VUP 2xDSD output to the DAC at DSD F5 right now.
It really remarkable how its presenting the cymbals and the brushes. More resolution, more realistic images (more 3d like and instruments separated better), seemingly able to feel the movement of the brush strokes in a way not ever noticed before (I have this in Redbook and 45 RPM vinyl). But at the same time warm, relaxed, it's less aggressive but more energy. Nice trick dCS has pulled off...
It's impressive dCS provides these upgrades to Vivaldi owners. Talk about building brand/dealer loyalty !!!
This was very straight forward to me. Click on the java8 app first in the package center/developer tools. Then click on minim server in package center/multimedia ..and it's done. Feel free to PM me offline and I'll see if I can help...On my DS716+II was as easy as a iPhone app...
I did the same - Java8 went perfectly. However when trying to install mimiserver from the package center it asks me to upgrade Java8 and stops! I have tried resetting from zero and installing again and the problem persists. Unfortunately I have no experience with Linux.
Try DXD, F3, MAP3 on the USampler and F3, MAP3 on doc. It's much more natural
I imagine with the soft top end of the Rockports your DSD setting would compensate if necessary but for rebook the above settings are best.....
mine is asking me to update java8, i better not...could be a java bug...have you emailed synology support? I'll you..the network input is pretty special in it's own right...
Using an alternative java8 solution, not the one coming with Synology NAS, I managed to install Minimerver. The DCS aplication now sees the server MinimServer[musica] (musica is the volume name) but shows No entries. I have created a folder called classica where I have some music files. Do you know how can I can get the DCS application to see the folder classica?
In minimserver did you rescan after you added files to the folder? This is done on the settings screen ... and has to be done every time you add files. Then click the status button to make sure minim restarted.
I'm assuming you entered your file folder address on this same screen after installation ?
Other than that - the dCS app just found it for me. (Assuming your routers are upnp compliant)
Thanks a lot - just did the Rescan and it shows the files now!
BTW, where did you learn about this need to Rescan? Is there any quick guide for ignorant DCS users?
