NAS drive up and working. Off the bat sounds better than USB flash key. Which sounded better than USB / MacBook
How does it compare with CDs played through the Vivaldi Transport?
Hi jfrech,
What is the model & config of the NAS you are using?
My friends are using Synology 415+ or 916+ because one of the four HD/SSD can set as a read-only cache. This improves sonic performance.
Also, 415+ or 916+ have large storage capacity yet the power-supply units are external. My friends made external linear psu for them which further improved the sonic performance.
Cheers,
CK
From the DCS site
FAQ: What are your reference network systems?
Our network products are currently developed and tested using the following.
NAS drives: QNAP TS412, Synology 216+, Netgear ReadyNAS Duo v2.
UPnP software: Twonky, MinimServer, Asset.
What are Twonky, MinimServer, Asset and what are you using?![]()
These are server apps that reside in the NAS and are responsible for indexing and serving up the digital files to the DCS streamer (renderer) My QNAP NAS comes with Twonky preloaded however since I use the NAim HDX to rip music and act as the server....I have turned Twonky off.
Thanks. Does the choice affect sound quality?
I was just gonna write now I tested f5 for dsd and pleased with it! Now saw your comments. Damn, these filters are so confusing)
Hi a DS716 II+. With Western Digital Red Pro drives (x2). I thought I'd try this config first. Then if I really got into it, I'd buy a 4 bay drive and do what you mention above. And move this drive be a back up to the main RAID. I may do the RAM upgrade on this DS716 II+ first and consider a different power supply.
Anyone have any power supply ideas?
So far stick to Filter 1 for DSD. To my ears the most accurate presentation of instruments including dynamic range and most appropriate proportions at the soundstage.
Wow, you can tell he put time and attention into build quality.Here are some photos of the products of a popular PSU workshop in Hong Kong. The boss is Kenneth Lau :
Interesting. I know this comes down to what your ears and your system likes best. No filter is "best." I did find I liked different filters after things were broken in...curious after a few weeks if you find the same.
#95
Your dCS stuff isn't even broken in yet...wait 4 more days and then start talking about filters and Map settings. You have no idea whats in store for you in 4 more days.It'll be like a light switch was turned on..
Thanks Kingsrule, let us see how it goes. What is your preference for filters may I ask?
