Really Mike? If you're going to act like an ass, then count me out. I was going to let you use all the equipment necessary to capture all the data.
I was just joking around, we don't need to be so serious here.
Sounds like a cop out if I've ever heard one. Bock bock bock!!![]()
Mike Davis, I didn't comment from that top quote above (yours), but I knew that some members would feel similar to what Bruce just expressed below you.
* Opportunity like this is precious, calculated balance between serious and humorous is also precious.
Bruce B. and Mike Lavigne are real nice people, asset people to read/learn/exchange with, very.
What about the myth of PCM upsampled into DSD being superior or vis versa? That would make for an interesting blinded comparison and one that could be done at your homestead Mike.....![]()
Well I have already busted that myth. What matters is the algorithms that are used. With the right algorithms, it sounds much better. Of course you need a DSD compatible DAC to do this. If it's PCM only, it won't sound very good. And yes it all depends on the DAC chip, or if it's chipless DSD or not. If it's chipless DSD, then you must resample the PCM to DSD to even listen to it. If it's an SDM chip, then it's being converted to SDM somewhere in the chain either way, whether it's internally in the chip, or on a PC. By doing the conversion upstream on a PC, it just bypasses the process in the chip.
You have to put that hypothesis to the test in a blinded fashion. You can't just blow smoke "like the golden eared vinyl crowd...."![]()
Analog soubuds different from digital..thats a given , and you need not test for that
AD'd analog vs analog is whats being tested .. for what reason I dunno .. most analog lovers would shudder at the thought.
However i have done it , with a simple 24/96 convertor and I can tell you that you cannot hear any difference tween the digitised vs the pure analog signal
Regardless of that -- I would rather have my analog unmolested if I had any.
Blizzard/Mike,
Actually, I had thought that Mike Lavigne had been too chickeny about this, but then, after reading his post, I thought his reasons for not doing the test were reasonable, and I applaud him for his post. You should read it again, honestly, you could learn from it.
You really do antagonize people, and your above reaction to his post proves it once more. You said that it was 'joking' or 'light-hearted' but it really doesn't come across that way. Rather:
1. your 'explanation' of it seems a huge copout itself, and
2. you really come across as a total ass
Your people skills are absolutely zero, or better, minus 1000.
You really need to grow up and work on your expression as human being and on your interaction with people.
Having said all that:
A big thumbs up to you and thank you for recommending the NADAC to Madfloyd!! It seems to be fantastic, and I cannot wait to hear it. I told you I was open-minded, and even recommended it to him following your recommendation and link to that Positive Feedback article.
You just have to get over your antagonizing people, and it will be all good. Your message will be heard much more. You really don't help yourself with how you currently present yourself and interact with people on WBF.
Yeah people skills take a nosedive after a while of being relentlessly attacked just for sharing innovative ideas.
It must be me.
No, Mike, you have been antagonizing from Day One, or soon after that. Please don't come up with excuses again, and don't dismiss what I said about your people skills. It's for your own good. Amir also was supportive of Mike L.'s post.
PS: I have edited my previous post in order to highlight my appreciation also for your help with the HQPlayer set-up.
Considering you are talking personalities , your way of putting things across is what aggravates .. you continually phoo phoo others ideas and are way too forceful and are never wrong...
You could have achieved much more with a softly softly approach as you undoubtedly have the knowledge..you catch flies with honey , not vinegar..
You didn't even know who I was till a couple weeks ago on the Analogue warmth thread. You said so yourself.
I'm not running for mayor, I am free to express myself openly and honestly.
Well, i had heard plenty things about you, so I knew what was coming.
BTW, as you can also see from Rodney's post, among many others, I am not the only one admonishing you.
It's really you who is the problem, Mike. Everybody who speaks up about the issue tells you that, except perhaps Bob (Northstar). And as for me antagonizing you, that was just in response to your antics, and I have had confrontations like that with nobody else on WBF, ever.
Wonder why that would be...
One thing is to be open and honest, another one to be a total ass. It speaks to your personality that you have no clue what the difference is.
I have a great solution for you, if you don't like how I express myself, stay out of Blizzard's corner. It's not for everyone. I don't hang around places that I don't like, why should you?
That is very good advice, except that you posed a listening challenge that involved people that usually don't like to hang around your Blizzard's Corner. And don't forget, my friend, that I supported your challenge.
I also showed appreciation to you for the NADAC recommendation and for the HQPlayer set-up in Madfloyd's system.
But perhaps I should stay out of your Corner. As long as you also stay out of other threads that are not in your corner, like the current "State of High End Audio" thread. In fact, you are obliged to, acccording to your arrangement with WBF.
Just leave the negative comments on the doorstep before you come in then. If you haven't noticed, negative comments always get a negative response. You are not helping anyone, or anything here.
