I can be a big help to you here. You can have your SET sound with several hundred watts of power for stats if you like.
Do what I once did. In my case, I much prefer push-pull triode sound to SET, but to each his own.
I once had a triode amp I thought far better sounding, more detailed, dynamic, tonally rich and discriminating than any SS amp. I did an experiment, in an attempt to see how much of this wonderful sound was lost by quality SS amps. I loaded the output of my triode amp with an appropriate sized power resistor. I then used Vishay resistors to reduce voltage so the amp output was exactly unity gain with the input. Put in 2 volts, and get out 2 volts. I fed this over DIY interconnects made or the purpose to a Spectral power amp (best sounding SS in my opinion at the time). I wondered would the Spectral lose half or two thirds of the musical nuance, dynamics, spaciousness etc. To my great surprise I heard the sound of my beloved triode amp. Proving to me the Spectral with lower distortion, noise and wider bandwidth really was capable of fully reproducing the sound of the triode amp, and that the triode amp had a beautiful euphonic sound that was not high fidelity to the input.
Interesting. I once had a Spectral DMC-15 Pre/DMA-260 amp combo in my system. Very little difference in tonal balance and richness to my parallel push-pull triode amps (on my benign speaker load they are not sweating much). Yet push-pull tube amps distort less than SET amps to begin with, while obviously their nominal distortion figures are still much higher than that of a Spectral amp.
But you said already that you prefer push-pull triode over SET. It is not quite clear to me if your experiment was with push-pull or SET.
