Insert Video And Insert Image Icons not working
Site Founder, Site Co-Owner, Administrator
Several members today (myself included) have reported that the insert image and insert video icons are not functioning
A service ticket request has been submitted to our site host and hopefully the problem will be rectified shortly.
Did you do that by using the button or typing in the tags? The tags work. It is the button that does not.
The button don't work. They did for me yesterday
I used the icons. Works fine on my end.
Good :). That means none of the changes I have found prior to that are responsible. There is one fix that was put in to avoid constant errors were getting that may be responsible. I put that that in the ticket. We could revert back and see if that fixes it.
Google Chrome and Windows 10 with last update.
I also noticed that the icon to the left of the insert image is also not working at my end
Chrome on Windows 7 is failing on me. IE kind of works.
Do we have any other members on Windows 7 and 10 do this and let us know what happens? It is possible this is a chrome update bug.
I have never updated Chrome. Is it done automatically, because I never received an upgrade notice.
I'm using Safari and none of those three buttons work at my end. They all did yesterday
I don't use those icons. I copy the URL and paste it in directly into the reply.
Now you tell us :). That functionality works. But the icons don't. So can you try the icons and see if they work?
Wait, wait....let's not confuse things.
I used the icons for VIDEO and IMAGE and they work fine on my end.
I DO NOT and have never used the INTERNET GLOBE(s) icons to the left of the IMAGE icon. I copy and paste a URL directly.
Chrome automatically let you know for an update; the latest version is: Version 47.0.2526.106 m
___________
From Windows 8.1 and using Chrome:
1. Insert Image => Doesn't work for me. So I do it manually with the: [/IMG*] brackets (without that snowflake* @ the end.
2. Insert Video => I use it but I have to type everything starting with: [url]https://www.etc[/url].
