Hi Andrew,
Could you be more specific what mobo model you are using for your pc built? I searched Google for TX performance but it turned out so many results. I am considering pc built also, which I am looking at Paul Pang's Asus mobo which has OCXO clock upgrade. I don't understand how do you passively cool the i7, could you elaborate more? And is the whole pc power supply come from Streacom ZeroFlex 240?
Sure thing - Technical Details
Motherboard Gigabyte H170N-Wifi mini-ITX :
http://www.gigabyte.com.au/products/product-page.aspx?pid=5552#ov
Processor Intel® 6th Generation Core™ or Pentium™ processor
Memory 2x DDR4 DIMM sockets supporting up to 32 GB of system memory
Graphics Integrated Intel® High Definition graphics (4k)
1x DVI-D Output max resolution 1920x1200@60Hz
2x HDMI Output 4096x2160@24Hz / 2560x1600@60Hz
Support for up to 3 displays at the same time
Audio Integrated Realtek High Definition Audio
2/4/5.1/7.1 channel surround sound
1x Optical S/PDIF Out + 5x audio jacks
Realtek ALC1150 codec
Networking 2x Intel Gigabit LAN chip (10/100/1000 Mbit)
1x WiFi 802.11a/b/g/n/ac adapter
Support for 11ac wireless standard and up to 867 Mbps data rate
Bluetooth 4.0, 3.0+HS, 2.1+EDR
USB 2 2x internal
USB 3/2 4x via rear panel + 2x via chassis side (left/right)
USB Type C 1 x USB Type-C™ port on the back panel, with USB 3.0 support
SATA 6x SATA 6 Gb/s
M.2 1x M.2 via motherboard
SATA Express 2x SATA Express
Expansion 1x PCIe 16x Slot (x16)
Yes, Zeroflex 240 powers the lot - its rated to 240w and I doubt even going full tilt I'd use more than 150 w.
The case I'm using comes with a heat pipe system that ports to the case - which is one giant heatsink.
I echo what Blizzard said: I am sure there is no necessity to spend the money I did. I am sure, with optical isolation, there will be absolutely no difference in performance between computers. I just put this together as I wanted it to be used for a number of different potential purposes - firewire, usb and ethernet and perhaps as a media server as well. I wanted fast performance and a dead silent server/player as mine lives in the listening room. I am sure a $500 jobbie would be fine provided you have fiber to the dac. Unless the part count somehow affects the SQ from eg Roon - and that is a place I am not going
