I have a pal with Giya G2's and a 200 devialet who uses Jriver
Bass was awful .. bloated one note..setting 3 simple parametric eq filters in Jriver totally transformed the sound , all below 200hz
I used a Umik1 and REW to find the trouble spots ..did the DSP and then tune by ear .. as any correction should not be flat .. you need to overlay a preference curve
I havent tried their full room correction , but have used Dirac, Acourate etc.. all work real well .. better in bass than at freqs over 300hz or so.
It's free with J river.. so you might as well give it a go.
Ypsilon electronics drive Giyas very well!
To bring this thread back onto its original track, does anyone else have any experience using JRiver's DSP room correction function? If so, how well does it work and how do you go about using this function?
Thanks,
Ken
The reason why no body has responded is because Jriver doesn't have a room correction function. There are some basic EQ parameters one could set. However, Jriver was never designed to be a stand alone room correction suite. One would need different software to generate the filters needed and those filters need to be added somehow to Jriver's DSP engine.
I've tried every software DSP method. I've tried generating custom EQ filters generated from REW. But the big advancement comes with using the Jriver convolution engine. One would use third party software to generate filters and install those filters in the Jriver convolver for best possible results.
Thanks DJ, this is exactly what I'm curious about. Could you describe what are the basic EQ parameters in JRiver?
Also, do you have any experience with third-party EQ software that could be added to work in conjunction with the JRiver engine?
Thanks so much!
Ken
Jriver has a basic EQ. Theres not much to describe. I've used the filters recommended by REW. That's very basic but can offer just okay results. The best solutions will be the filters generated by Audiolense and Acourate, IME. You will need a calibrated mic and DAC/ADC with a mic pre. You can demo either software. Of course, DIRAC can be demoed too but Dirac doesn't really work inside Jriver. It requires its own processor. I think Dirac is good but better results are possible using Acourate or Audiolense, IME. If you get the aforementioned gear, ask some more questions and I'll help out, if I can.
Yes but note that there is an unofficial VST-plugin version of DIRAC that does work within JRiver nicely.Of course, DIRAC can be demoed too but Dirac doesn't really work inside Jriver. It requires its own processor.
I don't use it with TV or movies so it is not an issue for me.That's true. I favor the Jriver convolution engine because it auto corrects for filter latency so there aren't any lip sync issues with TV or movies.
It is unofficial and you will have to inquire from DIRAC to pursue it.Looking to embed Dirac in Jriver as you've done -- could you point me to this plugin? An admittedly quick web search didn't yield anything useful. Thanks
Thanks so much!
Ken
Hi Ken,
I would not waste your time messing about with third party EQ software (as I did) and instead download Acourate and undertake full room correction using the jriver convolver having generated your filter in Acourate. It is easy to do and depending on how your room measured, might well be revolutionary for you.
