The downside of computer audio is the infinite variables.(...)
Exactly my point.
Any opinions on this one? http://www.soundstageultra.com/index.php/equipment-menu/587-highend-audiopc-audiophileoptimizer-computer-audio-software
Exactly my point.
Interesting hobby we have, don't we?
You've got me there, however I'm running an EQ program myself as a VST (MathAudio RoomEQ).I can top that. Doing the same while also applying Dirac DRC. On audio only I do MCH DSD -> PCM conversion and run Dirac. PC does not break a sweat....
...I could have settled on WAV but the tagging is lacking so I use AIFF for rips (offline converted to DSD128 for playback).
Actually everything is buffered into memory, there is no decoding on the fly. It is your playback software that will do this.
And if you are using a NAS to stream via ethernet there is total isolation between processing and DAC.
There are lots of brainwashed audiophiles out there.
To an extent - there are so many systems and variables.
I did critical listening comparisons in my system and I decompressed everything offline before playing when in the single computer + DAC configuration - WAV and AIFF sound better than FLAC in that config in my system to us (quite an old iMac now and Audirvana 1.5) and it's not even close.
Power spikes and concomitant ground plane noise associated with additional processing affecting the D/A at the DAC or also sending out noise through the mains, getting at the amp probably.
Ok Andre,
Then how do you explain the superior sound of the WAV file vs. FLAC file? I have done over a dozen direct comparisons of WAV vs. FLAC (my friend prefers FLAC files due to the reduced space requirements, so we trade them) and in nearly every comparison (all but one) the WAV file has sounded superior to the FLAC. In fact, I am able to pick out the superior sounding WAV files from the FLAC with my eyes closed. The biggest perceptible difference is the depth of the soundstage, although I do hear more nuance from WAV as well. My system is Audirvana Plus, Mac Mini, WW Platinum 7 USB, Esoteric K-01, Soulution 520 preamp, 501 mono amps and Raidho D3, so it is quite resolving. And I strongly resent being called "brainwashed".
Ken
Just realize that you are buying FLAC files which Jriver is coverting to WAV for you...
Now I ripp all my new cds to WAV and buy this format with HDTRACKS.
Just realize that you are buying FLAC files which Jriver is coverting to WAV for you![]()
Go back and re-read my last two posts...HDtracks has a WAV option I believe.
... In fact, I am able to pick out the superior sounding WAV files from the FLAC with my eyes closed. ...
It would be interesting to know if hooking up a Regen and/or a Jitterbug would change anything for people who notice a difference?I still say if there is an audible difference you have a crappy server. They are the same bits send to the DAC, and the only difference is a miniscule amount of processing done on the server do decode the flac.
You can always change your preference in the future. Unless your are ripping your own CD's (and maybe even then), all your audio files have been FLAC at some point in the chain.
Actually, Barry Diament's Soundkeeper label sells never compressed PCM recordings, and perhaps MA or Blue Coast does also; I haven't checked all the boutique downloadable labels, but all the major sellers send you FLAC whatever format you actually buy.
