I use isolation platforms. Having said that, some amps benefit from them more than others. Some like my Levinsons made no audible differences whatever I place them on. With my tube amps and hybrids, using different materials from wood, granite and acrylic did make differences.
What amps are you using?
Hi,
I am thinking about putting my 360s on cones, feet, pads or....
Who has their power amp(s) lifted by one of those and which ones do you recommend?
Thank your for the input!
Wim
Two I'd look into are the Wave Kinetics footers or the Silent Running stands.
