Yup, 100wpc and he is verrry proud of it, as can be seen by his quote...over the moon, actually!
It seems like the return of the differential summator circuit, for those Lampi Dac veterans from circa 2010.
Jazzhead, where are you located, if you dont mind me asking? If you dont want to answer publicly, PM me the response.
Winson ... Mumbai , India . Someways away from you . If ever thru these parts look me up . Cheers
Dude I am from Mumbai, but living in London. Let's meet up when I am there later this year.
Namaste bhai ! Look Forward !!! Do get in touch , will be great to catch up on all things audio and other Garam Masala![]()
I have a Skype pal in Mumbai who is interested in a Lampi....
Cant recall, but he is also hunting speakers. He is a pal of Adam too. I can give him your contact details...or better yet have him register here and contact you guys directly.
Based on this review, it sounds like the Big 7 without pcm dac would be most cost effective and instead using computer to up sample everything to dsd.
So I stand corrected. 750 Eur, not GBP. I wouldn't give up PCM for that, for anyone buying a Big 7 and a quality transport, that is not much as a percentage
Are there any performance advantages of just having the one engine? I.e. No switch, shared power supply, noise etc?
Yes , having both PCM and DSD boards nesscitates having an extra cap in the signal path , which seamlessly allows switching between PCM and DSD . This cap can be done away with for that touch of added purity , if you are willing to turn down the gain / mute the signal while switching between formats . Or else there emanates a boom , the technical reason of which escapes me .
