Help with DSD meta tag editor
Audioseduction
178
8
925
FLORIDA
I would like to modify some tags on some DSD files. What is the best software for PC? I have found a software called Tag&Rename.
Audiogate
Audiogate
What's the title of the software? ...... found it. I have to use the Lite version. Strange I open several files which I know for sure have the cd art attached but Audiogate shows there is no art attached. So I go to add one but it never does it. With Tag&Rename software I just drop the cd cover in a box and it updates the files immediately. As easy as that. Am I'm doing something wrong with Audiogate?
You are using .dsf files and not .dff, correct? Audiogate is the easiest I've used for DSD files. Pretty much like you said, just drop the album art and such and save.
Yes, .dsf files. You can't edit with the Lite version. I can't activate full version because I don't own any Korg equipment.
JRiver works as a Tag editor on DSD files.
Bruce..can i ask you, in your opinion, converting DFF to DSF is totally transparent? Like going from WAV to AIFF etc?
Bruce..can i ask you, in your opinion, converting DFF to DSF is totally transparent? Like gnoing from WAV to AIFF etc?
Yes it is
I can put a dsf file on one track and the dff file right below it, invert phase and they null to infinity
