Is there any other hobby with such a huge variety of snake oil products?
Keith.
Yes. The health and wellness hobby.
Keith.
I think antenna technology has progressed to where the physical size of the device is not crucial. The tiny size of cell phones pretty well demonstrates that.
Still, the device is bogus.
I love all the naysayers. Why don't you just try it (HFTs or whatever), they all come with a money back guarantees. There are numerous folks on this board who use Teds products, there is a reason why... they work. These naysayers are no different than the ones years ago when I began writing about SETs. Not a single (naysayer) person had listened to a single ended triode amplifier. Did SET go the way of the Tice clock? Hmmm. Don't think so. Our fearless leader here has them as his reference. You must keep an open mind with high end audio.
Keith.
So Peter, have tried the SR HOT device for headphones? Be interested on your impression of what it does.
Fractal design allows wideband antennas to be a small fraction of a wavelength (typically 1/16) in their major dimension. 1/16th of a wavelength at 7 Hz is still over 1600 miles... I await the result of someone opening one of these up and tracing the circuitry, as was done with the SR HOT device.
I use an open back RCA headphone to edit the videos, it's light weight and has a mini plug for the computer. I would not request a SR Hot sample for this set up. I will though receive the little HFT like devices for the phono cart.
One couldn't pay for a more glowing review. Hummmmm. That aside, This must be the first audio product in history that actually effects the listener. It is designed to change you and your perceptions by pumping RF into your room. Like I said before, if I wanted that, I can think of cheaper ways to get the same effect.
