I am guilty ,I have no defence I just like the way proper horns sound.
I will never ask for a blind test again.
Keith.
You are human after all!
Seriously though I applaud and respect you for that
Keith.
Keith.
I was asked on the Tripont thread about the Entreq Receivus and thought i would post my comments in both locations...i own 4 of them now.
1. The Receivus (to a non-techie like me) seems to be some kind of antenna-like thing...an oval disc that sits on top of equipment with a grounding wire connected to it that is then attached to the grounding box. As an antenna...i suppose it acts like some kind of hoover for emi/rfi?
that's a non-techie interpretation...like a caveman seeing an F-16 for the first time and guessing.
2. What it does in terms of sound is very very much like what signal grounding does...except that it not only works on equipment like my Gryphon (which has neither an extra set of inputs for signal grounding nor a chassis screw)...it ALSO further improved when on my 4-box Zanden (each Zanden box has one on top)...and each time it got that much better. Same effect: lower noise, greater detail, more natural decay, and better more natural beginning and ending of notes...
I suppose there is still emi/rfi that abounds in and around the unit (may even be generated by the unit?)...and the Receivus just picks it up and dumps it into the grounding box?
I got one to try recently and did not get any real benefit from it on my amp but that was because I connected to the one of my two Silver tellus which is used for grounding the Entreq ics I use and it was with a silver earth cable which was the only long one I had. I did that because there were 7 other earth leads to that Silver Tellus and the component one already had eight earth cables connected. Tried it that way on the power conditioner and DCS Puccini to see if it worked on them as it was not improving the Vitius SIA 025 amp which was its intended location, but no obvious benefit.
Yesterday I connected it to the Silver Tellus used for the components with an available Apollo earth lead and placed it on the amp. Bingo! Immediate and clearly apparent improvement with the MD 109 tuner
and subsequently with the Puccini. The amp had very clearly benefitted and the system now sounds so much better.
I will definitely be keeping it and have ordered an Atlantis earth for said Receivus. For £400 over here plus the cost of the earth cable it really is a good buy. As both the Silver Tellus I have are boosted by an Atlantis box the extra earth cable does not appear to be overloading the Silver Tellus but I suspect it would be better still with its own Silver Minimus
Good to know, thanks. So, based on your experience, the Receivus provides additional benefits to grounding through the signal plane, even for analog components. Do you know why your first trial was ineffective? Was it the use of the basic silver cable instead of the Apollo or the fact that the first Silver Tellus was maxed out?
I recall another member previously advising against mixing the the two sets of earth cables and given the clearly apparent success of the changeover I am sure that was the reason for the ineffectiveness of the initial trial.I don't believe the Silver earth cable was the culprit as I have used them in the past with no problems but almost certainly the Apollo has contributed to the improvement and I have decided to move up to an Atlantis for the Receivus in the light of Lloyd's experience.Nor do I think the Tellus was maxed out particularly as the second Tellus is now serving 9 earth leads .
I was advised some time ago that others who had tried the Receivus had all reported clear improvements including one who uses the same Vitus amp. So initially I was both disappointed and puzzled but that is happily all behind me.
So to sum up I judge it it to be a real bargain buy for amps, and that accords with what I had heard. The transformers in amps generate a lot of emi which the Receivus hoovers up thus complementing and further improving the sound quality improvements delivered by the signal plane earth cables. It makes me wonder if chassis grounding becomes far less important with a Receivus in place.
Cessaro only use these,
http://tad-labs.com/en/professional/unitspeaker/unit2.html
Too expensive for TAD to use in their own range!
Keith.
If they can stand the heat of my tube amps, I will certainly give them a try at some point.
If it is indeed acting as a sink for EMI/RFI, it is hardly surprising that it improved your digital front end. Was the effect just as significant on your amp? Also, was your Zanden front end already grounded through the signal and chassis plane when you added the Receivus?
The conjectured operation is similar to that of another product I use (which I will leave unnamed in order not to derail the thread).
The Zanden already had chassis grounding and signal grounding...and it still got better with Receivus on DAC, DAC PSU, Transport PSU and Transport. But in terms of a signal Receivus having biggest bang for buck...i would say Gryphon Colosseum (which had no grounding on it).
Thanks. Your experience and Barry's are consistent: biggest bang on the amps. My curiosity is piqued: I will get to it.
