LP with better dynamic range than digital
amirm
Banned
Apr 2, 2010
15,813
42
Seattle, WA
Post this elsewhere for a different argument but thought it is good to share here:
The highlighted ones compare the CD to HDTracks which only shows marginal improvement. The LP captures though, both outperform the digital versions on this metric. Clearly a less compressed master existed than the one released. And if there are no other issues with the LP, that is the better sounding one.
In a moment of weakness, I thought about getting a turntable but then sanity returned and I am staying with digital. :D
But well done LP lovers....
Amir, I'm finding this happens all the time on modern music. They put the ipod mastering on the cd and the real version on LP.
There was a time I thought I'd never go back to LPs Amir. All I can say is, I'm glad I did. ;)
The higher dynamic range on the LP version of this title is simply the super loud, untenable surface noise. :)
Stick to digital on this one, seriously.
The higher dynamic range on the LP is because of the way the DR plugin calculates the data.
Remember, to get the DR value of LP you have to sample it first, i.e digitize it.
The way the DR algorithm works produce (incorrect) better numbers for the LP.
I'm not doubting you, but do you have a link with a technical explanation for this? I'm genuinely curious.
Dynamic Range = Difference between loudest and softest portions
Crest Factor = Ratio of peak values to average values
The DR database is not dynamic range even though they call it that. It is crest factor. Crest factor has little to do with the dynamic range of the music. A metric similar to dynamic range is the R128 Loudness Range.
R128 Loudness Unit Algorithm Description
The input to the algorithm is a vector of loudness levels, computed as specified in ITU-R BS.1770
[2] with different relative-threshold gating, using a sliding analysis-window of length 3 seconds for
integration. An overlap between consecutive analysis-windows must be used in order to prevent
loss of precision in the measurement of shorter programmes. A minimum block overlap of 66% (i.e.
a minimum 2 s of overlap) between consecutive analysis windows is required; the exact amount of
overlap is implementation-dependent.
A cascaded gating scheme is employed which uses an absolute threshold of very low level, in
combination with a relative threshold of higher, signal-dependent, level.
The purpose of the relative-threshold gating is to gate out any periods of silence or background
noise, using a method that is independent of any level-normalisation of the input signal. The lower
edge of Loudness Range should not be defined by the noise floor (which may be inaudible), but
should instead correspond to the weakest ‘real’ signal. The relative threshold is set to a level of
-20 LU relative to the absolute-gated loudness level. The purpose of the absolute-threshold gate is
to make the conversion from the relative threshold to an absolute level robust against longer
periods of silence or low-level background noise. The absolute threshold is set to -70 LUFS,
because no relevant signals are generally found below this loudness level.
I have 3 versions of Elton John's Madman Across the Water. Here are the DR and LRA of each album for the Madman Across the Water song:
DR 13, LRA 13.6 (DJM Records W. Germany)
DR 10, LRA 11.7 (MCA Records USA)
DR 8, LRA 13.3 (HD Tracks)
Another metric that is useful is R128 dBTP (db True Peak). There are intersample peaks which can be higher than 0 dB. These can lead to distortion if the digital levels are not attenuated (i.e. using analog volume control). Here are the dBTP for the same 3 albums:
+0.5 dBTP (DJM Records W. Germany)
-0.4 dBTP (MCA Records USA)
+0.4 dBTP (HD Tracks)
You can see that while the HDTracks version has the lowest DR rating, it maintains is Loudness Range (or dynamic range) and is the only one that won't clip or cause distortion if one isn't using Volume Leveling or digital attenuation. I think the reason the DJM album has a higher DR number is because it has a higher noise floor. This is probably similar to MadFloyd's suggestion that the surface noise of records causes a higher DR number.
When you cut a lacquer, its impossible to hear its surface noise no matter how quiet your electronics are. The surface noise creeps in during the pressing process. Currently, QRP has the quietest pressings we have seen. Chad Kassem claims this is because the took extra care to eliminate vibration during the cooling of the vinyl in the pressing machines.
Something else to keep in mind: the less bits you use in digital, the less resolution you have. You don't dare go over 0VU in a digital recording; a 'tick' is the result, and could ruin a recording. To get around this problem many projects are compressed when going to digital so that they will sound better and be tick-free.
LP OTOH does not need compression as there is no loss of resolution as signal level is decreased. The limit to LP reproduction is in playback, where the groove might not be tracked properly due to excessive excursion. You don't have to compress the LP to deal with this, but you do have to be careful of the level. Sometimes there is nothing for it, but instead of compression limiting can be used more effectively.
So it may very well be that you see less compressed information on the LP. It depends a lot on the label and the mastering engineer. Some houses don't care a hoot and use the same file for digital as well as analog; others do care and you will hear a big difference between the two. An uncaring mastering engineer might just slap some compression on so they don't have to take time with the recording and then its all over.
I have done MANY demos with the vinyl of this album - and the response has universally been "Man, I've heard this album a million times because my daughter/son plays it and it has NEVER sounded this good. I'm now a fan!" I have the download, the CD and several copies of the vinyl. I think that the vinyl smokes the digital. No comparison at all!!
I'm confused....I thought that if something measures better it has to sound better :D
There you go, you're listening with your eyes again.... now cut it out!!
If you have a listenable pressing then consider yourself lucky. I have tried 3 of them, all extremely noisy.
MadFloyd, your experience suggests that it was not the LP that was noisy. I am guessing that you don't know this (many audiophiles don't) but the playback electronics (the phono stage) can do things that make surface noise really stick out- to the point that an LP has unacceptable surface noise. The way this happens is when the RIAA equalization is contained in a feedback network in the phono stage, in such a way that the circuit is able to echo the tick or pop (thus enchancing it) in a way that it does not exist on the LP surface. Yet when you place such units on the bench, they meet the RIAA spec just fine.
IOW, not all phono sections are the same, and a good phono section will appear to have less ticks and pops than a poor one. Price is no object here; design is!!
Ralph, it was the LP. I have a large LP collection and a very decent phono stage. I know a bad pressing when I hear it.
Ironically the first copy I got had a pretty decent side 1, but side 2 was bad. The two replacement copies each had two bad sides. I didn't check the pressing plant, but I know this happens with a lot of pop LPs.
Someone should take the time to look at the actual waveforms of these various formats. Just an idea.
For years I used the audiophile iconic CD from Patricia Barber, "Cafe Blue", as test material for improving my system. No question that the midrange on that recording is outstanding. But I jumped through a million hoops trying to improve my SYSTEM because the drums and cymbals never ever sounded correct. On some tracks I couldn't even tell if it was real cymbals or electric cymbals used on the recording. Then, one day, I got the LP. And it was no comparison! The LP blew the doors off the CD. And for the first I could hear an accurate rendering of the drums and cymbals.
So I used a Tascam to record the LP straight to digital and then compared that waveform with the CD waveform.
To this day I can hardly believe what I found. The CD was clipped beyond belief! It many spots, the waveform was a near flat line across the top of the spectrum. All the dynamic life of the recording had been literally chopped off the top.
I still can't believe that I have yet to find anyone else in the audiophile community that is aware of this on the CD format of this iconic "audiophile" recording.
And, as an aside, it proved to me that the reason so many audiophiles buy into crappy sounding systems is because they don't a have a flyin clue what instruments are actually supposed to sound like.
(Then again, like Harley says, "It's all good".) :-/
I have run into certain pressings of certain titles that had pressing defects (notably- Porcupine Tree's first press of 'Signify'). Sounds like this might be one of them. In the last 15 years, I can still count such things on one hand. So you still have any of the LPs in question?
Pretty sure I do. They just get moved to my basement.
