Grills are for cooking!![]()
Always on
If The Lord wanted them off, they would not have been designed or shipped. Got to be one of those audiophool querks. It's all in ones head![]()
. . . speakers with grilles have them in their acoustic design.
With some speakers, yes. Grills are an integral part of the speaker design. IME, the vast majority of speakers yields your statement untrue. I for one know for a fact it's not in my head. There is a change, it's not positive and that is why I personally listen to my main speakers with the grills off. If you look up the benefits of a properly designed baffle and then slap on a grill that many manufactures supply for a WAF or quasi protection attributes, all or most of the design parameters of the baffle are thrown out of the window creating the change in sonics.Always on
Tom
Because the designer is my friend and he says despite picking the best grill material they found, they recommend using it without itHow do you know the greater treble without the grille is what the speaker designer had in mind?
How do you know it isn't compensation for having the grille on?
It could be worse:I can't believe some are ready to argue over whether grills should be on or off.![]()
OK, I'll bite here.
Grilles ON the woofers for protection.
NO grilles on the midranges or tweeters--they were designed to be bare.
I admit I can't hear the difference with the woofer grilles on or off.
