Kenny Burrell Midnight Blue AIFF 24/192 from HDTracks. Magnificent sound and great music to boot. I can't imagine the 2 channel master tape could sound any better. The mastering is that good.
That should also be available as DSD, as it's on SACD. The SACD is wonderful indeed...
My DAC doesn't do DSD. I have tried some DSD using Audirvanna to convert it to 24/176.4. Can't say I have been impressed. Maybe some day I will spring for a DSD only DAC. Not right now though.
No reason for it to be DSD only!...Maybe some day I will spring for a DSD only DAC...
I have heard plenty of DSD on other dacs and systems. I prefer PCM. Sorry.
Cool, but that's not what your above post said. If you prefer PCM to DSD that is fine. I would get your ears checked as soon as possible though to make sure you don't have some potatoes growing in there.![]()
by chance, did you have vinyl or tape and so have a reference for analog sound. how did the dsd and PCM compare to the analog sources?
or maybe in those other systems where you heard dsd how did the dsd and PCM compare in those systems where you had an analog source to compare?
No need to get your panties in a bunch as I'm just teasing you. If PCM makes your socks roll up and down I'm happy for you.
