Thanks for the correction.These are not anodised , more a paint finish . I believe the thickness of the front plate does not permit anodising, or so I am told . I" ll take it in the buff please![]()
I believe Vitus are using a variable bias design for the MP-S201 similar to what Boulder are doing.
Jdza, well Vitus UI-core transformers are much more efficient than traditional toroids which lose up to 25% voltage. For the MP-S201, vitus quote <2% loss. In saying that, I just made reference to a comment made by Hans Ole Vitus in which he only briefly described the biasing of the MP-S201. The commentary did not include a detailed technical explanation of the MP-S201's design or topology, so it would be wrong of me to make make broad assumptions without having something like a technical white paper in my hands.Except that the Boulder 2060 is specified to consume a quite believable 5000W peak to deliver 600W+600W and the 3060 6000W to deliver 1000W + 1000W vs a specified 10 times lower consumption on the Vitus for similar power delivery. If we assume a typo and the Vitus power consumption at max is a more believable 5500W then the 2x 2kVA power transformers must be slightly inadequite?
If the quoted consumption of 550W at max is correct,the Vitus is even more efficient than a Crown Macrotech amplifier. The Crown is a long, long way from class A,no matter how it slides.
Those input sensitivity numbers look delicious![]()
I may very well have missed this (won't be the first time), but is the 700/1400 watts output in Class A/B and if so, then how much of this output is in Class A?? Anyone?
Looks fantastic, but I'll stay pat with my Mephisto for the foreseeable future.
Currently, I'm very intrigued by Spectral and will be venturing to Goodwin's to check it out.
I wish Vitus well with his new baby.
Intelligent class A control means:
Vitus measures the temperature on the output devices – and adjust bias slightly – to maintain a temperature on the output devices within +/- 2 degrees. This way he ensures that the temperature is stable and the sound he wants is maintained at all loads. (...)
Yes that is true, though I don't really think you can compare a stereo amp to mono's at this level since a customer who has the money to buy such a creation would likely buy the mono's if that's what they wanted. I even heard of one client at Munich who wanted an MP-S201 custom made as an integrated...which Vitus was happy to oblige.Nothing personal . Just a correction in comparison. Gryphon mephisto stereo retail for 1/2 the price of Vitus MPS. So Mephisto solo is a more appropriate comparison
Thanks Jazz, i've gone back and edited my post. That was my fault as it was the one spec I didn't double check.Bodhi , good stuff .. However the MP-S has a 2.25 kVA UI core each side so total 4.5 kVA .
That's the first time i've seen a full Vitus spec sheet. I recently gave Vitus feedback I think they need to offer more technical info, so that's good to see. And yes, superlative figures indicating excellent engineering![]()
