Generally, the process here will work for native DSD playback on Foobar:
http://www.audiostream.com/content/how-play-dsd-file-using-foobar2000
I don't specifically know about the Lampizator, but this works for other DSD DACs.
The main problem I had with the Lampi is it needs to have DSD over DoP. I couldn't get it to work otherwise.
It's the ONLY way it will work Bruce. Did you run it from Windows or Mac? If Windows, did you use FooBar or something else.
Gary-Here is the funny thing: I double click on the listing foo_dsd_asio, nothing happens. It won't open up and give me the screen shot you are showing above. I don't know why double clicking it won't open it up.
Are the correct drivers installed?
Bruce-The foo_dsd_asio driver is there, I just can't double click on it and make it open. That driver has to be there for the Mytek DAC to work and the Mytek works perfectly (or at least it did yesterday until I monkeyed with the settings to try and get the LampizatOr DAC to work over FooBar).
