You are right. I'm just a music lover.
Michael.
+1 & +1
Thank you,
zz.
Michael.
I understand (and agree with all that, of course) but it has mostly to do with the artistry of Strauss, Fleming, et al., and says that the sytem conveyed that to me. Perhaps my remarks conveyed some emotional response to you (intended) but what did you take from it that differentiates the equipment in use from any other?
Btw, Billy Gibbons graduated from Robert E. Lee high school in Houston. That's where I went to high school. I am only 40 though so I never met him. Why is the guy named Beard the only one without a beard? I never figured that one out.+1 & +1
Thank you,
zz.
Hi Kal,
What's the importance of a high end system if it can't convey the artistry of Strauss, Fleming, et al.?
david
OK, OK. But what do you learn from that?I have listened to many systems having great accuracy but that were not able to create the effect you describe and I have also experienced "Here Ms. Fleming’s glorious soprano soared over the spacious carpet of Strauss’ orchestra and thrilled me". The subjective unique perception suggested by the words soared, spacious carpet and thrilled made me believe that your really felt it and the speakers in the configuration described were able to transmit it.
I must say appreciate when a reviewer is not afraid of using appropriately terms such as thrilling or goose hums.
Btw, Billy Gibbons graduated from Robert E. Lee high school in Houston. That's where I went to high school. I am only 40 though so I never met him. Why is the guy named Beard the only one without a beard? I never figured that one out.![]()
Sure but, as I said, one can get that from a table radio. The kick I get from a high end system is my personal emotional response.
Yes, you can get that from some table radios and there's the rub for me when it comes to high end systems costing tens of thousands. The gear head in me is always interested in the equipment but he gets bored very quickly without that other thing. I've probably been at this a bit too long...
david
Exactly. My choices of music and my comments about them tell you more about me than about the sound. However, they do provide a context for the specific comments about the equipment/sound.IMHO, any one wanting to get information from a review must know the reviewer and his preferences and his emotions. It is not possible to get it from a single capsule review - readers should carry their homework.
I agree with you in that measurements matter.I
As to measurements: They do matter, if done right. If Stereophile measured YGs, then you could expect that all of them will measure exactly the same way. I strongly believe these type of measurements directly relate to subjective enjoyment.
Michael.
In fact JBL has done research (blind tests) showing significantly that people prefer good measuring speakers before not so good measuring speakers (unfortunately I do not have the link).
JBL has a room with a "motorized assembly line" which easily replaces a pair of speakers with another one, making this research possible (for most of us, such a precise blind comparison of speakers is difficult).
This says that this hobby is not so subjective as some say.
(Regarding YG: As you probably know, Stereophile has measured YG's performance).
(...) JBL has a room with a "motorized assembly line" which easily replaces a pair of speakers with another one, making this research possible (for most of us, such a precise blind comparison of speakers is difficult).
Hifikontoen is this the link http://www.uniquesquared.com/blog/pro-audio/jbl-hearing-the-truth-testing/
I do not think that this is correct.Yes, but it is used mainly for their developments, not to optimize high-end. For example, in their speaker comparisons they always place both sets exactly in the same position, ignoring that different speakers can need different positioning and do not care about using typical audiophile high-end systems.
OK, but I disagree.IMHO ignoring the subjective aspects does not make you objective.
Hi David. You are naturally there are subjective things like taste of music.Of course its subjective, starting with the music.
david
I do not think that this is correct. (...)
