Has anyone compared the Minimus directly against a Tellus? And the silver versions of each? I have just a Moon MiND streamer and Devialet 170 and am wondering if it's worth the outlay for the Tellus bearing in mind I'd only be using one binding post? I guess I do get the option to attach the speakers too with a Tellus, but again not sure how much extra benefit that would give.
Hi
New here, so second post.
A bit of background on the system
I have a soundproof and acoustically treated dedicated listening room, about 25' X 15' X 9'.
The electrical supply, is a three phase, dedicated, separately metered supply. Each socket is individually wired from it's own circuit breaker, to a single unswitched wallplate.
The system is comprised of Magico V3s, Mark Levinson ML 432 power amp, Mark Levinson ML 326S preamp, Ayon Stealth DAC, and Ayon CDT transport.
All cables are Siltech; power cords, XLR interconnects, and speaker cables.
Equipment sits on a Finite Elemente rack, with all supported by Cerapucks.
Many who have been in the room, with previous systems, have thought it was overdamped, I think.
I do like listening from a distance; the speakers are about 10' apart, and I sit about 15' away.
The current system sounds very open, clean, fast, and generally, very good, with no apparent peaks or dips, or other nasties.
My approach to Entreq was throughthye UK distributor, and the typical approach of Silver Tellus, and two Apollo Rca leads. I wasn't bowled over, and thought things sounded a bit bright, and din't help the flow of music much.
As the Troy system attacks only the power earth, and not the signal earth, I thought trying that approach with the Entreq was worth a try.
As my budget is limited, we tried a Cleanus, Tellus, and three Apollo spade leads. I ran one cable from the Cleanus to the Tellus, and the other two went to the chassis of the preamp and DAC.
I thought there was a noticeable improvement in flow and timing. I then upgraded to the Silver Tellus, more improvement, and then an Atlantis spade from Cleanus to the Silver Tellus.
I thought that would be it, but I did try a couple of RCA leads on the preamp and DAC, and that improved detail and speed.
I don't know why, nor does Frazier and Per Olaff??, but the mains earth side seems to do more of what I want, than the signal side.
I can't afford a Silver Cleanus, or an Atlantis Tellus, or even more Atlantis cables, but I think if I could, attacking the mains earth does more of what I want, than the signal earths.
I preceded this session, a week before, with the Troy system, which was £20,000.
As it is a modular approach, and much more cost friendly, I feel the Entreq system gives you a real taste of the Troy, at affordable levels.
I have just come across a good review of Entreq grounding boxes and cables by Roy Gregory. It was done for Audio Beat dated May 2014.
A good and informative read but pre Atlantis and Apollos.
Yes like most things that are done thoroughly and concisely there is a lot to take in, but the benefits repay the effort.Yes, a good read, though I personally found myself having to read and re-read it due to the number of iterations he ran! Very thorough. I generally found myself that Silver Tellus, Atlantis are superior...but in a few cases I did not mind Apollo at all, or in 1 or 2 cases (more in the AC wraps than the grounding)...I actually preferred the 'regular Entreq AC wraps' to their Silver ones.
