I'm considering it. I must admit however under my Amps is also enticing BUT I sene I would need 16 not 8 as my amp is dual mono and dual power supply.
I would try 3 under each of the subwoofers. Saves you the cost of another two units. Yes, your amps will be an expensive venture. They produced significant positive results under my amps.
I'd be willing to bet they'll make a more apparent difference under the amps, but I wouldn't assume that 4 will be better than 3, and I definitely wouldn't assume that optimal placement will be where the amps' current feet are.
If I were to use them I would with adapters and place them where the feet are. It's just thinking of buying 16 doesn't sit well with me. I actually use 3 Aurios M1B's under my amps but not under the power supplies
Why would you do that without even listening to alternatives? Not even Stillpoints or their dealers suggest that one way is best for all situations.
Do these elevators improve sound or neaten up the room only? If the former, what kind of sonic improvements? My floor carries loads of vibration so I am curious. Thanks.
Thanks, Steve. Good to know.Lloyd
I can't hear any sonic changes but YMMV. They do tidy the floor and the mini elevators can be used behind your rack to separate cables. I really like the mini elevators and they hide well in my room
Galen Carol is a Stillpoints dealer. do you think they would give you an honest answer about what you might expect with Ultra SS compared to what you have? It's probably worth asking, and there's always that money-back satisfaction guarantee![]()
That has nothing to do with it. The ultra 5 is a sandwich of two SS metal pucks with their bearing technology in between, hence the wiggle room. If you ever hold one in your hand, you would understand.
