Using Ayre's Analog to Digital converter from an LP source.Not sure how this is valid at all. How were these files originally mastered?
(...) For some reason my PC would just play the PCM files instead of download them. I will have to try it again on another PC.
If you use Firefox just open the options of your browser, select applications and mark the .wav type as save. It will save the file instead of playing it.
it only proves that Charles likes the PCM files better than the DSD files, through his A to D. .
Guess Charlie needs go build a better DSD A/D converter then!![]()
Anyway this is even further compounded by the ADC-recording chain where it can be seen the latest next gen top studio products from either Merging Technologies or DAD are going different ways with PCM/DSD; DAD have even come out stating they stopped using ESS Sabre in design of the new AX32 due to technical performance/behaviour minor anomalies.
Or use a proper converter in the comparison! Seems to me even the Korg can do better than his unit...
alexandre
Which is what I did with this comparison.
That suffers exactly from the same limitations and problems, except that the source material (master-tape) seems better suited - IMHO you were mostly comparing the Korg used as encoder with the Mytek used as decoder, not comparing the formats in an absolute way.
