Does anyone have opinions as to the best type of electrical wire to use for a dedicated audio circuit? My current dedicated circuit is 20A romex, but I'm considering replacing it with 20A or 30A twisted wire in metal conduit.
I wonder how long before somebody uses shielded silver inside conduit from their service to the outlets...
It's only a matter of time until someone pays their power company to run dedicated lines from the substation directly to their house.
As to the power wire/cable, this newer Bill Whitlock & Jamie Fox paper adds a new prospective.
"Ground Loops: The Rest of the Story"
Bill Whitlock, AES Fellow and Jamie Fox, P.E.
This paper was presented at the AES 129th Convention, 4-7 November 2010, San Francisco, CA, USA
ABSTRACT
The mechanisms that enable so-called ground loops to cause well-known hum, buzz, and other audio system
noise problems are well known. But what causes power-line related currents to flow in signal cables in the first
place? This paper explains how magnetic induction in ordinary premises AC wiring creates the small voltage
differences normally found among system ground connections, even if “isolated” or “technical” grounding is
used. The theoretical basis is explored, experimental data shown, and an actual case history related. Little
has been written about this “elephant in the room” topic in engineering literature and apparently none in the
context of audio or video systems. It is shown that simply twisting L-N pairs in the premises wiring can
profoundly reduce system noise problems.
http://xa.yimg.com/kq/groups/20963848/268252969/name/Whitlock-Fox+-+Ground+Loops+.pdf
'zz' you really need to read parts of the white paper. But don't try to read the patent application, as it will turn your brain to mashed potatoes.
The JPS Labs cables uses 5 twists/ft in their cable.
Bruce, Are the JPS Labs cables approved to install in-wall without conduit like romex?
Is PVC used as conduit of electrical runs? In the last build I saw the conduit was all metal. I suspect it depends upon the current code, which I am far to lazy to go look up.
