Yep, I agree - it' something that is important with loudspeakers as well. How they play at low volumes. Is the sound still intelligible at "everybody else in the family is asleep but I still want to listen to music" levels.
Actually Peter Quotrop of Audio Note talked about the importance of the first watt long before Nelson and I'm sure somebody did before them. And Tom Colangelo and Mark Levinson about minimizing output device and real world performance.
Know everybody has their preferences but this continuing love affair with Quad 57s just escapes me. Very, very limited and flawed speaker that barely does one thing well. YMMV...
(...) Gamut has a simlar philosophy and uses just a single mosfet output device for similar reasons. from rufus smiths review:
"Danish designer Ole Lund Christianson's Gamut D-200 amplifier differs from its competitors in the high power sweepstakes in its use of a single high power MOSFET to produce its rated power. Previously, most high power amplifiers made use of multiple transistors operated in a parallel fashion to produce their rated power. The major drawback to this design philosophy is that no matter how hard you try; you are never able to completely match the transistors. As a result the signal that is produced is a mixture of the signals from all the parallel-coupled transistors. According to GamuT, the result is that the fine details found in music can be lost."
I've heard cases where the smaller, less powerful, but otherwise similar circuit amp was more refined sounding (ML 33H verses ML 33 back in the day). the bigger amp had more devices in the circuit and was a bit more congested sounding.
in the case of the darTZeel 108 compared to the 458 monoblocks, the 458 has fewer devices in the signal path than the 25% as powerful 108......and therefore sounds more refined as well as more powerful. even on a speaker that demands little from the amplifier (96db, 6 ohm), the first watt of the 458 goes much further into the music. from the read out on the 458 it rarely outputs above 4-5 watts continuous and 10-12 watts on peaks into the MM7's.
That's why you should have a dedicated sound room that is sound isolated from the rest of the house. Having said that, the KEF LS50s are the first speakers I have owned that still sound incredible at low levels.
I am currently using a Burmester 956. Tried two monos of the bigger model 911. Price ratio 1:3,7. The overall sound quality went down. Bass and treble boost. Midrange lacking and metallic.
Will consider one or two Burmester 909, the top model. But I can not know what happens with the sound. A test in my setup is not easy to arrange for this type of 80 kg amp...
I've had in my system for almost 4 years the 956 Mk2 and I found it a very musical and refined amp. Later on I compared (and then purchased) with 911 MK3 (stereo and monos) and the difference in terms of sound was superior in all regards and awesome and I have never turned back. I know also well the 909 MK5 (stereo and mono version) and sonically I like it very much, but at my ears with a mono-pair of 911 Mk3 is reached the heaven.
Are the monoblocks on the same or separate AC lines?
Sounds like you are comparing a well run-in 956 to brand new 911's. I've extensive experience with all three of Burmester's big amps, and I much prefer the midrange transparency of the 911's (in mono OR stereo) to the 956. I think that the Burmester amps are all very balanced - going up from the 956 to the 911 to the 909...... although I do prefer mono 911's to a single 909.
My ears concur with your ears, Rocco. Although, I have heard that with extremely power hungry speakers that mono 909's beat mono 911's - but is is very loudspeaker specific.
