Joost
I switched back to Dartzeel from my other gear and I have to admit - Dartzeel rules my TADs. The overall listening experience is wonderful. There's nothing fancy. Nothing stands out in an objectionable way and the music flows. Detail and nuance without being harsh. A very natural presentation.
Joe- The Dart on the TAD's is incredible indeed. I think its tough to beat in a small listening space. Extreme high level of resolution/inner detail, micro/macro dynamics, holographic imaging, highly natural and musical presentation with great tone and weight. As you say nothing stands out or is missing.
I personally have found that the 108 is better alone than with the 18NS; with the pre I loose a little resolution and energy in the higher frequencies resulting in a presentation that is overall too dark for my tastes. Going direct into the 108 with my DAC is absolutely spot-on perfect in terms of the so called 'brightness' of treble energy. The CR1's pointed so that axii cross over directly at the listening position also maximises the energy in the treble and gives the most 'airy' presentation which is my personal preference.
Hi all.
i'm here again. Listening my new Tads Cr1.
Actually paired with my integrated Dart. Like my listening room is smaller than the dealer's room i listen the bass deeper. But I'm still waiting the open scene and full bass than i listened with the Classe Audio Amp. i'm waiting for the Classe Ca-m600 amps to compare it.
Hi all.
Actually paired with my integrated Dart. Like my listening room is smaller than the dealer's room i listen the bass depper. But i'm steel waiting the open scene and full bass than i listened with the Classe Audio Amp. i'm waiting for the Classe Ca-m600 amps to compare it.
Hi Audio.Hi Stereo, any further updates on your amp quest? Are you currently running the Classe M600 mono's? Still the same impressions as compared to the integratedDart?
Hi Audio.
I was listening in my room the cam-600's ( Dart as pre ) and once compared to the Dartzeel that are my conclusions:
The sound didn't seems anyway to what i listened in my dealer's room.
Dartzeel's timbrical sound was far better than the Classé.
Anyway, it wasn't a serious listening and i have to listen it with the Classé CP-800.
Joe, indeed interesting amps! Is this from CES '14? I guess we might be getting some impression popping up in various places of this system...
