DSD downloads at Acoustic Sounds....
that makes at least three of us that finds this newsworthy. big news, really.
it will be interesting to see how the DSD files were derived from the anaolg masters, i dont see any mention on chad site.
The only piece of DSD equipment I see that Kevin Gray uses is the Tascam DV-RA1000
Clearly Kevin states on his website that he proudly uses the PM2 converters since they are "the best". I wonder if these DSD files are just PCM upsamples?? :confused:
I asked on the thread that Myles started if anyone knows the source of the DSD files. I'm hoping they came from the master tapes and are not up-sampled 16/44.1 files.
Being that Chad has reissued all of these on LP and SACD, I would assume he started with the master tape.
and obviously he already has the (master tape sourced) dsd files sitting there from all the SACD's, so it won't cost Chad a dime to get the files.
That's if Chad first captured them in DSD. All I see on Kevin Gray's website is the Pacific Microsonics PM2 converters.
I'll drop Chad a line.
Reposting this from the other thread, but the Nat King Cole and 50 Blue Note SACDs were all supposed to be done on the Grimm AD1 according to Steve Hoffman. Not sure if Kevin Gray still has that converter... those reissues predated his new mastering facility.
http://www.grimmaudio.com/news_archive.htm scroll down to May 2009
I wrote AS and thanked them for doing this. I'd generally be giving them a LOT more money than I do now (and I already give them a LOT for LPs) for DSD. I can't rip SACDs so they currently get no $ from me for digital.
I did ask them to make .DSF files though (I don't see any reason for .DSD files - does anyone here?) as I want to be able to store metadata in each file. I can convert .DSD to .DSF with Korg's free utility but not without tweeting the world about the details.
Slight correction.... they are all DSD files. You meant .dff files as opposed to .dsf
Thanks for correcting me, Bruce.
Is there any downside to .DFF files that you know of? Are there some players that won't play them?
.dff is the default standard that will play in all things DSD. The only downside, as you know, is you can't attach metadata.
Then that's not the format I'm thinking of (not at home to check my files). The format I'm thinking of is the one WITH metadata. What is that format and is there any downside to ONLY offering that to customers?
then that format is .dsf and as far as I know, I haven't checked, I believe all software can play that as well. I know at first, .dff was the only format you could play, but I believe that has changed now.
to confuse you even more, the other DSD format is .wsd, which is a Korg proprietary format. You don't have to worry about that though.
I think you are wanting to convert .dff files to .dsf.
