repeat after me
"I will never buy another amp or preamp. For those who have heard the ML3 understand how amazing it is.
It can always get better....
repeat after me
Don't the latter blow up occasionally?
What I'm getting at is that there's a difference between deep bass from a sub and dynamic bass that a powerful SS amp delivers. Otherwise, Fremer would have emulated Steve's setup. Instead, he has been sacrificing the midrange of tubes for "slam" and the other benefits of monster SS amps.
FWIW my room size has resulted in far better bass than I would ever have expected, so much so that my subs provably could be removed. They are used mainly for rock. There is no doubt in my mind that subs are not necessary in my room with XLF's as well as my X2's
Seems a little unrealistic to say that only 2 companies can offer to reproduce piano and female vocals "perfectly".
I'm sure there are many more out there. I'm only going by what "I" have heard.... I can't comment on what I haven't heard like so many people seem to do!
Gee, I'm glad I have the 3rd....![]()
It's not easy at all to perfectly balance external sub(s) with the mains, no matter what.
Interesting review....seems to me the Lamm ML2.2 measured better than the ML3 reading both stereophile reviews (less distortion in the bass). It would be fun to hear them both in the same room.
i think the more egregious set of measurements was for the B&W 804 which has noted frequency response issues, but was given a clean bill of health.
Hi Keith
I heard the ML 2.1 (which I owned) with the ML3 shortly after Vlad released it in my sound room. There is a "magic" about the ML3 that the 2.1 didn't have. It's a very holographic image. Keith you were planning to hear my ML3 with a buddy of yours. Let me know when.
I have never quite figured out what makes a holographic image possible,but when you hear and see it,and I do mean see,it is very special. I hate the description synergy,but the sum of the parts,seem to play a important part. I would say the speaker are most important,followed by the amplifier. There is also different degrees of it and it always can get better.
Roger, i think to what you said, you need to add the most important factor....the room. Great speakers in a poor room and I don't think you will get the desired result.
Roger, i think to what you said, you need to add the most important factor....the room. Great speakers in a poor room and I don't think you will get the desired result. IMHO, we can put in order of importance in creating the illusion of a holographic image the following:
1) the room 2) the room 3) the room...and then a distant 4th) The speakers and then 5th) the front end ( I would have NO problem replacing this as 4th and the speakers as 5th). 6th) The preamp, 7th) the amp, 8th) the cabling and everything else slightly lower. Naturally, YMMV.
