Just what we need...more snakeoil. Please!
Well, in order for it to be snake oil it would have to do nothing. If that is correct, this one is not snake oil.
Whether or not it will work to each person's system to satisfaction is a different story. In my system, adding or removing it is clearly audible.
Dre
Sorry, but I'm really skeptical about these kinds of tweaks. Glad to hear you feel it makes a difference in your system, as that is all that really matters.
Dre
This is not a wearing part. That being the case the supplier should be offering free home trials or money back guarantees, should they not?
It is obvious that it will make a difference. The crystal must have some mass. In the additional information it says mass 1LBS, better get a new conterweight![]()
Kind of depends on what kind of adhesive they supply to attach it. Can it be removed and reattached easily?
I wonder what cartridge manufacturers think and if using it will void any warranties?
What kind of damage could Lloyd's tweak do? Other than someone not reading the instructions where resetting your VTF is *emphasized*.
BTW, there's also HFT dot for cartridges too.
Hi Dre, Can you describe the differences you hear in your system using the crystal? Is it a positive change or just a different sound?
