This may be stupid, but why don't these devices, like turntables and active suspension, use Nitrogen like we use for our equipment in the hospital?
You don't have to worry about moisture and drying out seals.
This may be stupid, but why don't these devices, like turntables and active suspension, use Nitrogen like we use for our equipment in the hospital? You don't have to worry about moisture and drying out seals. The large tables in the labs use it and I think they even use it in tires as well.
No I'm serious. It is something that is used in human behavior modification. If you look at the Wiki piece and then were to read the book, you would see they are really one and the same. People often resist large changes in behavior; the belief is that the challenge is so great as to invoke the brain's fight or flight response (primitive brain). The book talks about how to reduce the challenge and make it easier for people to change their behavior/habits.
Dear Distributors and Friends,
Please find attached the revised Mechanism Figure of Air Force One.
As you may know, the suspension of Air Force One has been improved. It is now an all-air suspension. The Mechanism Figure was updated to reflect this change. All Air Force One units shipped since May 2013 have the latest suspension.
The details of the new suspension are as follows:
We always thought that air provides best suspension. So we made the first suspension as an air suspension. However, due to the internal structure of the air suspension, the amount of the air that can be filled in the suspension was limited. Also, with this structure, there was a small problem of air leakage. So we changed the suspension to air/liquid hybrid suspension.
After that, we designed a new internal structure of air suspension. Now we can fill much more air in the new aluminum air chamber inside the suspension. The amount of the air in the new air suspension is three times (3x) compared with the first air suspension.
As a result, the ability of the suspension to absorb resonance of low frequency is better than before (if you knock the surface of the turntable, you will only hear very small noise.) This leads to better sound quality.
There is no change with the external appearance of the suspension.
Although it will be necessary to fill air to the suspension at setup and add some air once every few weeks as explained in the manual attached to the turntable, we are sure that you and your customer will be satisfied with the improvement.
Also, it is possible to update the old suspension to the new suspension. The upgrade kit will be provided as follows:
- If you can send us back the replaced insulators freight prepaid and if they are in good condition without scratches or damages, we will offer you one upgrade kit for one Air Force One unit for JPY 190,000.
- If you cannot send us back the replaced insulators, we will offer you one upgrade kit for one Air Force One unit for JPY 380,000.
i feel a little bit sad about this change because my AFO is gel and air version actually at first i order air version because i have micro seiki BA600 air base and i know how great work . when delivery my dealer say techdas has change to gel and air. i feel disappointed . but have to accept it and now it change to air like what i want in the beginning . and my dealer say if i want to change need to pay for 6000-7000 usd !!! i think techdas should have some replacement upgrade policy .
thanks
ps i don't like gel version because it move like jacker!!!! hoo hoo hoo move like jacker... ( turntable always trun around and go to one side not central of the leg!!!)
In order to store and use pressurized nitrogen is closed spaces you should have leak sensors and safety systems - release of nitrogen gas into an enclosed space can displace oxygen and represents an asphyxiation hazard. There are reports of people who have died due to nitrogen poisoning.
When I had my VPI HRX, putting air into the bladders every few weeks was a royal PITA as they used to leak at different rates.
I hope the TechDas is a bit more stable and user friendly when "airing" up every few weeks.
Gary wrote above that the air-loaded-gel-filled bladder is the latest but the problem has always been the bladder. So perhaps there is no bladder in this latest design. Do you know how the new design gets around the bladder issue? If there is no bladder, how are the air and gel contained in the suspension? I'm curious because the air bladders are a persistent issue with the isolators in the Vibraplane and they are very expensive to replace. My new units don't have issues yet, but my older one is not quite as stable.
actually techdas should put automatic pump with gyro scope system when open afo will start level up and automatic level balance . or other when you play hiphop song afo will shake it self up and down like hiphop car. haha
