great
I think i am gonna sneak the portable B 62 into the Amsterdam concertgebouw , and do some recording![]()
Mark has sharp eyes, the VU meters have burnt out lamps on both channels. In addition, I am not sure if it is just the photos but one of your transport photos show both Play and Stop PB lamps on at the same time. If the machine is at Stop mode, it should not have both on. Also one of the other photos show Rew and Stop PB lamps on at the same time as well. The Stop lamp should blink only when you hit the Zero return button and while the transport is trying to get back to Zero count and before it comes to Stop. If the lamps on at the wrong time, you should check pull up resistors in the PB assemblies. I have seen few that got hot and have changed their values or if the PB switches are solid-state version in your machine, they may be faulty and need to be replaced.
The head seems to have plent of life left but the reflection show on repro head as having possible worn flat part to be more than 1/4"... If so, you will have difficult time sweeping 20 - 20Khz. Maybe it is just the photo or have it relapped.
Based on seeing new caps in your transport power supply regulator board, rest of the transport cards have new caps. I can't see your audio power supply regulator board to see if the two big filter caps and two smaller 47uF caps were also replaced. I assume so.
As for the audio boards, you will find that if the tech didn't make modification to C34 470pF capacitor (Polystyrene type) on Record Amp card, your VU meters will go beyond full scale when biasing for modern tapes such as ATR or RMGI 911/900 etc. I would suggest C34 to be changed to 150pF or lower to increase dynamic range of your record bias.
For both Record Amp and Repro Amp boards, your photos show older generation A101 discrete "opamp" devices (black rectangular part in Record Amp and blue potted part in Repro Amp). Since you are in Europe, it should be easy for you to obtain modern replacement A101s from a seller in Germany (eBay).
Lastly, there are caps on both Record and Repro Amp boards that must be replaced (and yours had been done so). However the electroytic caps on signal paths are debatable. Some people (who know more about Studer than myself...) consider the Tantalium looking caps (but they are not Tantalium type) are Studer special ingredient that gives the Studer "its own sound" and would be dead against replacing them. If you have spare boards, you can try them both ways and make up your own mind.
As I had stated elsewhere, it is far better to have a well taken care of Mk I (or just A80RC) than worn down and neglected A80RC MkII. You have a very nice A80RC from what I can see.
Its a cheap old camera/videocamera , i ll upload some more b 62 recordings in the future with a more decent camera
http://www.youtube.com/watch?v=9ShUwF8_Eu0
