Hi Amir,Hi Clive. First, welcome to the forum. I hope you don't get the idea from this specific interchange that I/we in this forum are against high-end or have a dogmatic attitude toward "prove it or not." We don't. I am an engineer and call myself an objectivist but have an extremely open mind about what we know and what we don't know. This discussion is not about "everything can be measured," "DBT is the only answer," etc. It is not about changing DACs and expect them to sound identical.
Rather, it is about something very specific and different: can the high variant PC traffic be tamed in a positive way by changes in the way the application reads samples from disk and output them. It is a given that apps like JPlay attempts to reduce traffic as the music plays by prefetching data. And its "hybernation" mode reduces background traffic. The issue at hand is knowing what I know, says that all of this may do nothing, or as I showed in the last analysis actually make things worse. In jitter for example, we don't care about megahertz jitter. We can't hear that. If you reduce that by a factor of 1000 then you now have jitter in KHz that can be audible. So less it not necessarily more.
Does this mean JPlay can't be making a positive contribution? No. It can. I am not here to rule it out. I am here to explain how the system works and diminish the intuitive sense we have that if something reduces activity automatically means the wind is behind them in having an advantage. That assumption will set one up for massive amount of placebo to be injected into the evaluation. Just like the example I gave in my comparison of Foobar and WMP. I thought the former used a direct pipeline and WMP did not (i.e. bit exact) and therefore may sound better. And sound better it did. Once I confirmed that the pipeline was the same, then that bias went away and so did the perceived performance advantage.
BTW, I have huge respect for Paul Miller and his work in analyzing digital systems. He is the only person testing and reporting on such in the world. It is an absolute shame we don' have more journalists like him. More of a shame is the fact that the articles are not online. Had not heard about his USB cable tests. I would love to hear more about that test. Can you describe more of it? I will go to the book store and see if I can find a hard copy too. Thanks in advance.
Thank you for your kind welcome. I should say a little bit about myself. I am unashamedly a subjectivist but I'm also not totally technically unaware, I've built a lot of diy projects and have a reasonable scientific grounding but I'm more commercially focused than technically focused. Since the early 1980's I've been a contributor to Hi-Fi News and then Hi-Fi World and more latterly to an internet magazine.
The Paul Miller and John Westlake examples I gave were not intended to be directly applicable to the JPLAY situation but they were indicators to my thoughts about some of the objectivists measurements played out on the forums being not necessarily up to the job. To an extent the examples I quoted were an allegory to your balls in a car example. I have a huge experience listening to very varied equipment, I like to think I'm not easily fooled; this is a British understatement
The reverse of subjectivists being fooled by hype and looks is objectivists being fooled by inadequate technical measurements, both are clearly extreme examples. I believe temporal aspects are vastly underrated and I expect we will soon work out their importance, there will be a lot of egg of faces.....the Paul Miller USB cable test is just the start. I can't copy the text as the magazine article as it has only been out a few days. BTW I find DBT is one useful tool but it's limited, real life experience of a breadth of products is frankly much more useful and way more rapid in terms of useful conclusions, good DBT tests are incredibly hard to set up and execute without bias.
