Does the Oppo use a Sabre? Sabres with good transports and first class analog output stages are a potent combination.
Yes. It still uses the Sabre. I just ordered a ModWright OPPO 105 a few days ago. Should get it by the end of the month.
I have a sneaking suspicion though that even valves aren't first class enough in this instance given the horrendous demand for dynamic range presented at the output of this chip.![]()
I thought those posts knew what they were talking about, based on their previous comments. I guess I was wrong.
We are in trouble if a 6sn7 valve is not dynamic enough for a chip with I suppose has rails of +/- 12 or 15 volts !!
in answer to bold, well, yes, noise comes into it too and linearity and speed and such
I guess I am lost in here, I assumed the chip was putting out an audio signal, not sure exactly where we are talking about electrically and such in this instance, or even if the output of the class d amp is filtered for audio already, etc, so...perhaps you could help us know what we are talking about if you please
You were indeed mistaken. Posts know nothing - they're quite literally 'dumb as a post'.
Yep - linearity is the name of the game here.
The classD amp turns out to overload the AP and compromise its dynamic range. Same thing happens with the output of the ESS chip, except its even more severe because that's much faster edges (though lower in amplitude) than a class D amp. Yes its putting out an audio signal but its RF 'carrier' signal is high amplitude, around 1.5MHz. I've yet to see any analog backend where the 'carrier' signal is filtered out to any significant degree prior to being fed into an active stage.
What happens to that RF noise if the downstream equipment does not amplify it? No audio eq I'm aware of has a bandwidth that high. Does it inter modulate with the audio signal?
likely the same effect: overload the input stage of the EQ.
You would think someone would notice a problem if it was significant.
Indeed it does - precisely my point. In my estimation it needs filtering out before being fed to anything active (even an ultra-linear tube), but I've yet to see a design which does that. I would love to be shown one though![]()
Well that's an interesting comment - yet DSD has been around for a decade at least and Stanley Lipshitz noticed there was a problem with it close to the start. Hasn't stopped anyone much yet...![]()
