Mike, did Herve manage to retain the "magic" sound of the 108 in the mono's? Are they just a ballsier version of the 108 or sonically different in any way?
"and then some".
my 458's only have approx 200 hours so far and so they have a ways to go to be optimal, maybe approaching over 500+ hours i'm told before the whole picture comes into full focus. yet beyond the additional weight and effortlessness, there is already another level or two higher refinement and liquidity over the 108, as well as a 'see into' and 'see around' aspect to the sound which is an altogether different thing. and the delicacy is unmatched with anything i've heard other than the 45 Tube SET's i had briefly a couple years ago.
the effortlessness cannot be overstated as allowing such detail and harmonic richness to be easily percieved. watching the readouts of current watt output and peak output on the front of the 458's shows how little the MM7's are asking of the 458's. the highest peak i've yet observed is 210 watts; which was when i fed it an initiial big drum hit with the volume in the wrong spot.
most music is in the 0 to 4 watt area, rising to 10-20 watts from time to time. then peaks can get higher.
i'd say 'magic' of the 108 x 2 or 3 so far. stay tuned.
the 458's have the same if not a bit more clear and open top end of the 108's; the 458's have a slightly more fleshed out mid-range along with more tonal density. yet a higher transparency. i'm doing my best to describe my impressions with my limited vocabulary and word skills. hopefully i'm not painting a contradictory description. in my mind's eye i'm trying to recall how i percieve the differences and i sort of jump around with snippets of thought.
noisefloor is hard to compare. both are very quiet, a vanishingly low noise floor is one of the huge attributes of the 108 over any other amp i have heard. yet the 458's uncover more detail, in some cases lots more...and you get this weightyness and ambient definition that is eire. yet i cannot say it is quieter than the 108. both the 108 and 458 have very low parts count in the signal path.
looking back now i'm glad i had 3-4 weeks with the full MM7's and the 108's to be able to fully appreciate what the 458's can do. my 108 did sell this week and is on the way to a new home.....it is a great amplifier and it took alot to top it.
