Is this something you know for sure or is it a conjecture? I know for a fact that some resistors used for crossovers in passive speakers have a heat sink (Caddock comes to mind but also some Mills) ... I could be wrong but I need a fact not a conjecture to change my positions. Something I am more than willing to do.
I am far from an expert in crossover design IOW I know close to nothing .. I know however for browsing through DIY websites through that for most drivers you need more than filtering ... You also and often need to linearize either impedance of frequency response of the drivers. These increase the level of complexity and inefficiency of the crossovers, esepcially for first order which often are much larger physically that other (not a rule). In the case of woofers often a Zorbel Network is used to flatten the impedance cure of a given driver... SOme of the power that would otherwise reach the woofer is lost in the reistors of the Zorbel network. I suppose High End speakers to have the same constraints and the designers to employ similar compensating networks.. The results are to be wasted energy ... Not opinion ... facts..![]()
Frantz,
So what of the insertion loss in passive xovers , how is this detrimental to the sound apart from slightly lower efficiency , if efficiency is within means then it's all part of the metrics necessary for FR bandwidth control and lower distortion , it does appear you are trying to make a case for listening to your choice of IC's , so best to condemn passives .. ...
Better for you to get beyond conjecture Frantz , where's the proof pure active works , where's this digital magic you speak off , why is it better than passives ?
Please tell us where to find this fully digital active speaker , the ones i have heard are way off the pace and are not even close to their passive cousins ..
Regards ,
So why do many of us have large box loudspeakers... It isn't about playing louder... It's about a) reproducing at a larger scale b) doing so with minimal electrical and mechanical stress that causes distortion which leads to fatigue which leads to a listening session that for lack of a better word, sucks. The very same reasons one would need and thus seek large panels.
The plain fact is that there are things box speakers do better than panels and vice versa.... From what I see now, box speakers have caught up to panels in what panels do best and may yet surpass them if the trajectory is maintained. It is panels that are making slower progress in catching up with what box speakers do well. The best panel systems still come with boxed woofers.
Frantz,
The only way of effectively proving it to you would be computing or measuring the different power distributions in many typical passive crossovers and then debate if the chosen circuits would be representative. I could for example pick a crossover with a minimal number of resistors and get a very efficient design and another person could pick the famous Sonus Faber Extrema - a crossover in which the series element of the tweeter circuit is a very hungry power resistor. In my perspective most crossover belong to the first group and only a few exceptional are part of the second group. Most of the time we just debate in WBF the "a few" versus "most" .
I respect the DIY community and I am sometimes jealous of them - they do while we talk - but most of the time (please note the most) they design by belief than by technical reasons. In the case of resistors, most of the time people add the heatsinks just to minimize the temperature variations that could affect the resistor value due to the temperature coefficients, or just because it will looks nice. But they forget about the delays of heat propagation in solids in their argumentation about transient response. For a similar subject you should look at the net debates on the miraculous use of copper in the D'Aggostino Momemtum dissipators.
The damping and Zorbel resistors usually take very little power - they effectively ameliorate the amplifier drive by reducing the phase angle and variation of the impedance.
I disagree. Materials, labor, R&D are expensive especially for relatively new companies.There is also the problem of limited product runs. Von Schwiekert says in the video I posted on the VR44 a an aluminum cabinet can cost $30-50k. . . . .
What's your point microstrip? I kind of got lost there ...
My point is that you asked for proof ... And I am answering that I can not give a formal proof as you requested ...
I am putting many ... in my answer, perhaps you will not get lost this time ...![]()
A. Wayne
Active crossovers allow better approximation of the mathematical functions that describe a crossover. Digital crossover are even better on this regard. TO the extent that some find them transparent read around this forum. The Digital Room Correction part.
There are several exmples or active digital crossovers based systems. The Cabasse La Sphere is one of them Entirely digital Active speakers or for an actively crossed over/digital amplifiers with DRC.. Completely digital you go to Steinway Lyngdorf... tacT used to make them too. There is system from Australia or New Zealand an Apogee Like speakers with DEQX and non digital amplifiers.. The Lyngdorf site will show you example of active digital crossovers and digital amplifiers based system... The DeVialet now offers active digital crossover in the D-premier and those are the few examples to come out of my head .. Oh before I forget the Bang and Olufsen (!) Beolab 5 .. You can pooh-pooh it all you want it is a valid example of a fully active digital speaker/system Like you told me the other day you may think about going out a little more
Frantz,
There are many ways of implementing a crossover, no one has proved that the classical simple mathematical functions you are probably referring to lead to a better sounding loudspeaker than the practical functions implemented with passive components. Just because the transfer function graph looks nicer does not imply that it sounds better.
Don´t you find curious that the digital active systems that you refer to be known of sounding good cost a lot? IMHO, what separates them from lesser sounding ones is the care taken in the full implementation, not just the active digital crossover.
BTW, I have played a lot with the DCX2496 - when used above 150 Hz is does seriously affect the sound quality of my system. None of its electrical specifications can explain why.
I have nothing per se against digital crossovers. The concept is very tempting. But when I read people reporting that pure DSD sounds better than PCM at any rate I can not endorse a system that inserts a PCM 96kHz AD and DA without a lot of judging. I think that any implementation has compromises, we must debate which one allows us to have a better sounding system.
IIRC somebody is advocating infinite baffles subs. I concede that is probably not a practical solution for most audiophiles.
Hi
Let put aside the truisms. That “ there many ways to implement a crossover “ is one of them. Modeling that is , reduce a device or phenomenon to a manageable set of equation or assumptions. That’s what is done with speakers. Any speaker from the squawker in an iPod to the Alexandria you now enjoy. The drivers also are modelized (allow me this term) . I will dispense you of the definition of a model, you know it better than most people here. We do that with speakers and guess what? These models are a pretty good indication of what these speakers can do thus the famed Thiele-Small parameters that describe very well a driver. I am certain that David Wilson and the Wilson Audio Engineers look at the Thiele-Small parameters when they have to choose drivers for their speakers, before even turning a signal on the drivers .. You will not tell me they go around listening to drivers before they read their specs (based on measurements and of course models). If it were the other way they would spend a few centuries listening to all the drivers available on this planet … The crossovers/filters are also approximation of a mathematical filter. And I can guarantee that WA make sure they have the best software available for the purpose, the software output are based on mathematical models … then they make their filters to approximate those equations and of course they listen, no problem there .. As for approximating the mathematical equation that are the filters , it is something passive crossovers simply cannot do as well as the digital ones at least in speakers. That is the power of DSP this is not an opinion it is a fact.
Now implementation is another thing s and I don’t claim that all implementation of digital filters are perfect, never did. I maintained that Digital filters approximate the mathematical functions better than analog ones and that again is a fact. Whether it sounds good to you is an opinion and I am not debating that you may simply not like anything digital some here are of this persuasion. I am not.. That is my opinion you are free to have yours.
If we are to discuss what “cost a lot” is we are in subjective territory. I however believe that the TacT that someone here use and who many think is rather transparent in that capacity is not that expensive, please allow me this subjective term in a universe where some speaker cables cost $50,000 and are trending toward $100,000. At less than $5k it is not. The Trinnov is in line with a decent non-digital, non DRC preamp at less than 7K and the Lyngdorf DP-1A under 6 K is right there in what we audiophile would call “affordable”. “Cost” a lot ? Not sure. Recently a very generous fellow by the name of Alan Jordan remarked that the extremely cheap Behringer DEQ-2496 is good sounding when everything is kept in digital ($287.85 at Amazon.com with free shipping). The DCX-2496 OTOH has to transform any input in digital and back to analog for the output. At 224.83 with free shipping from Amazon, it is likely that the Analog to Digital ( A to D) conversion has to cut several corners pun intended. Then it has to convert that into analog. No wonder it doesn’t sound that good over 150 Hz. In the bass it shines. No surprise here, that has been my observation as well, we are in agreement but let’s not forget the DEQ-2496. And you can bet your X-2 that the DIY is abuzz finding ways to make both the DCX and the DEQ objectively and subjectively better for not much more? Need I go further? No? OK
Some people say that DSD sounds better than PCM at any rate? Fine. Not my opinion. It is their right to their opinion. I can’t debate that. I am however suspect when I read however that a person find a PCM to DSD conversion better than the original. A copy better than the original!!!??l. Equal? Ok. Better? …….. !!??!?? The laws of Physics haven’t changed in spite of the End of the World that was to occur yesterday.
Happy Holiday to you ALL People!!!
http://www.whatsbestforum.com/showt...t-And-should-they-be&highlight=panel+speakersI spoke to the designer of the Sony high end speaker and he told me that they did a lot of testing. He said an "after taste" of the cabinet was unavoidable. Here's a quote from John Atkinson's review of the smaller Sony speaker:
"He experimented with many different enclosure materials, including aluminum, but no matter how stable and solid he made a loudspeaker's cabinet, it still produced sound, ie, distortion. The important thing, therefore, would be to control that cabinet-produced sound: If the wood is going to vibrate anyway, choose a wood whose vibrations can be controlled, and are consonant with the music, not dissonant to it. "The sound coming from the cabinet should be as beautiful as possible," he told me..."
Interesting.
Hi
Assuming that "Thiele-Small parameters describe very well a driver" is nice for DIY building subwoofers, not for professional manufacturers.
Originally Posted by FrantzM
(...) As for the complexity of crossovers it is almost a necessity with passive speakers. This is not the subject of this discussion but it bears to remind that passive crossovers are extremely wasteful as most of an amplifier output is used to heat the resistors and inductors in passive crossovers …
Frantz,
Unhappily this myth propagates fast. Most high quality crossovers use coils of very low resistance and resistors are used in positions where energy dissipation is very low. IMHO people get this idea because most designers use large power resistors in their crossovers.
