An entry level sytem
Gregadd
1,814
1,850
Metro DC
I decided to make a suggestion for an entry level system.it will be a:
integrated amp
outboard dac
mini-monitor
digital source(computercables
later a phone section might be added.
Our friends at Stereophile have comprised a list of integrated amps. A good place to start.
http://www.stereophile.com/category/integrated-amp-reviews
tablette.jpgMy all time favorite is the Proac tabette
The Proacs' forte is its' ability to image. It is a true point source.Specifications
Nominal Impedance
8 ohms
Recommended Amplifiers
10 to 120 Watts
Frequency Response
35hz to 30Khz
Sensitivity
86.5 dB linear for 1 watt at 1 metre
Bass/Midrange
5 7/8" (150mm) Polymer Impregnated Kevlar cone with black acrylic phase plug
Tweeter
3/4" (20mm) ProAc silk dome with damped front plate. Mirror image offset configuration.
Crossover
Finest components on dedicated circuit board. Multistrand oxygen-free cabling throughout, split for optional bi-wiring/ bi-amping
Dimensions
Height: 10 5/8" (270mm), Width: 6" (150mm), Depth: 9 3/4" (235mm) including grille
Weight
5 Kgs each
Mode
Stand/Shelf mounting
Grille
Acoustically transparent crimplene
Finish
Standard Finishes:
Black Ash, Mahogany, Cherry, Maple.
Premium Finishes:
Rosewood, Ebony.
*Premium Finishes to
That cabinet reminds me of my first amp from the 60's: A Scott model tube amp with (drum roll please) 12.5 watts per channel!!
Love that look!
Looks nice but:
Summing up the Cayin SP-10A's measured performance is difficult; it must be remembered that this is a relatively affordably priced product when compared against the similar-looking Leben, Luxman, and Quad integrated amplifiers that Art Dudley reviewed in November 2011. But I am concerned about its 4 ohm tap's curious instability and lack of distortion-free power. As Bob wrote, the amplifier just "ran out dynamic gas" when asked to play loudly with rock music from this output.—John Atkinson
Rob
Looks nice but:
Rob
Good observation. No doubt the Cayin is a classic tube amp. My thought is a separate amp speaker combo for hard rock.
Thanks Gary. I've always been a fan of satellites since I experienced the M&K system.
Maybe you have some thoughts on reasonaby priced cables
No thanks. I don't want to go there - every thread on cables on this forum turns toxic.
Don't worry Gary, I got your back.
How about Kimber Hero?
DUT: Hero 1m terminated with WBT-0144 RCA type connectors.
(Cp) parallel capacitance: 76.5 pF @ 20 kHz
(Ls) series inductance: 0.401 µH @ 20 kHz
(Rdc) dc loop resistance: 0.033 ?
(Xt) total reactance: 0.051 ? @ 20 kHz
Frequency response ± 0.5 dB dc - 8 MHz
DUT: Hero 1m terminated with XLR type connectors.
(Cp) parallel capacitance: 33.10 pF @ 20 kHz
(Ls) series inductance: 1.13 µH @ 20 kHz
(Rdc) dc loop resistance: 0.081 ?
(Xt) total reactance: 0.143 ? @ 20 kHz
View attachment 6682...
I want to suggest Harmon HK 990 that has a phono section. it was reviewed in Stereophile by our own Kal Robinson.
http://www.stereophile.com/content/harman-kardon-hk-990-integrated-amplifier
---- Yes. :b
---- And yes. :b ...I use KK Heros myself; very affordable 'performance' interconnects.
