I guess it depends on which country's Mil Spec ...
If that poor quality of soldering is indicative of a country's best effort at mil-spec soldering, they aren't too high on the peckng order of countries with advanced electronic assembly skills.
Maybe MEP will get an invite one day to listen and be converted ...
(...) I liked it to the extent of buying a Reimyo CDP777 that Gary (or the dealer) used for the demos.
The Reimyo CDP777 was an excellent CD player - I regularly hear great sound at a friend system using this player. At the time it was presented it sounded less "mechanical" than most of the competition. Unhappily JVC discontinued the mechanism and it seems that it was a fundamental part of the great sound of this player. Do you still keep it?
And let us know what you end up buying!
Hmm, that's a tough one. FMA? Ya think??
mephisto stereo and 1811 sounds different - while 1811 sounds neutral not cold or warm, mephisto is on the warm/rich side (with neutral cables/preamp/speakers this richness can be toned down)
both are musical, easy to like - but mephisto can't match the 1811 sound quality.
But of course the mephisto stereo price is a bargain compared to 1811 - sound quality mephisto stereo around 130 (monos 140).
Both have total control of the sound, mephisto is fast, but 1811 is even faster. Mephisto is a very powerful amp with a very big power supply - 1,5kw peak at 2 ohms and 3kw in 1 ohm - no problem to play
very loud on the kharma's.
1811 loves to play at peak levels because of the special transformer - 3,2kw in 2 and 5kw in 1 ohms.
For best sound and to play at this power levels 1811 must be connected to the mains with a 32a connector (same as boulder uses)
normal levels - power output in 8/4/2/1 ohms - both in class a - mephisto very hot, 1811 hot too, but not like mephisto.
Mephisto - at 1% distortion - 175/350/700/1400watts.
1811 - at 0,01% distortion - 500/900/1600/2500watts.
1811 - at 0,005% distortion - 400/700/1200/2000watts.
Hey...at USD$130K a throw...vs Mephisto at close to 1/3 the price...i thought i would ask just to make sure!
I said that because the Wiz is an FMA cult member of the highest order. All other amps pale in comparison to the mighty FMA amps (except in looks, build quality, parts quality, chassis quality, etc.)
And hear it you should. Let us know if you do and what you think.
