I had a free day today so I figured I'd get my bedroom system up and running. I've been running hybrid amplification for my main system for quite some time now so I figured I'd dip into my old equipment stash and set up an all tube system. The Unifield 1 monitors are set to be delivered so my personal pair of Unifield 3s, like the ones attempting to tide Mike over until his MM7s arrive, got pressed into now permanent service. I also finally put them on the custom U3 stands made by Solid Tech.
I pulled a back muscle (must remember to warm up and stretch before playing, my age is showing
) but fortunately both drivers were around to lend some muscle. The whole time we were setting up the CMS Sapphire amp bases and laying out the cables, I kept wondering if some failure would happen with the amps being in storage for so long. These amps had been sold before but had somehow found their way back to me. As such, I had no idea about the source and state of the 6c33s. I first purchased these amps in 2004. They are BAT VK-150s which are basically a pair of VK-75s that are single ended bridge paralleled producing 150wpc. These were my main amps until I switched to the Lamm hybrids.
Before powering up, old memories came back to me. The optimist that I am, I was remembering how much I loved the midrange these amps provided when I used VR-4 SRs and later VR-5s. I also remembered how I wanted more control down below and my failed attempt to mate them in bi-amp with my Levinson amps at the time hence my switch to hybrids. As I switched them on, images of fuses blowing came back to me and with it came some tense moments. Would the green LEDs for each tube go on? The tubes began to light up then moments later.....Click, click, click, click. Whew! Now for the other one. Click, click, click, click. Yahoo!!!!!!!!
I took the next few minutes to do a bit of cable dressing and to give the amps more time to stabilize. Then I hit play. Ahhhh. Effortless sound. The U3 is a pretty light load. Normally I run them with only 50wpc mono blocks. I had plopped the speakers down where they usually go and they were giving the same predictable results. I was thoroughly enjoying myself and 9 tracks in, it happened.
Pop. Pop.
Fortunately it's daytime here. B+ fuses blowing in a dark room can look like a lilliputian Thor was throwing a bachelor party inside your amplifier. Not a pretty sight. Bad tubes, not one but two. It could have been one but it likely took its parallel auto bias partner with it hence the two dead green LEDs. I then remembered Mep and his wrestling with his Defy 7s. The fuses are on the bottom plate of the amplifier. A bit of a bee-yotch considering these amps are luge sized and heavy. Fortunately, the service of the local BAT distributor is top notch. It won't take very long until I get a complete set of replacement tubes and fuses. I could have saved a little by ordering from a tube store but I know that the two that blew were not from my original BAT supplied stash. I know because I number them.
So I guess I'll just have to wait it out. I ordered a pair of KR Audio DXs maybe these will arrive first. Damn. Tube amps can be a pain in the ass. I wish they didn't sound so good.
Pop. Pop.
