Bruce-How did you pull that off?? I waited over six weeks and never received one and gave up after different dealers told me they had no idea when they would receive them.
I've had this in the system 24/7 for about 2 weeks now and can say I prefer this over the DAC section in the Korg MR2000s. This thing really shines in the bass department. The leading transients on plucked bass are sharp and authoritative. There is no grain or smearing in the high end. I can play the same DSD file from the Sonoma going through the PD MPS-5 and then from HQPlayer going into the Mytek and I prefer the bass from the Mytek! In the mid region, it’s an even playing field. I can’t tell them apart. On bells, cymbals, and recorded sibilance, I prefer the PB. It’s not night and day though and you can’t make the determination from an A/B comparison. The factor I go upon is, does it capture your attention when you’re doing something else? When I’m doing tape transfers, breaking in equipment and such, I do other things like editing or house cleaning. If I hear something out of the ordinary, I can immediately catch it. I was breaking in the Mytek and Muddy Waters was playing. I immediately stopped what I was doing and actually wanted to turn it up and listen! This thing got my attention. It’s something on the order of like listening to CD’s all day and then suddenly a 24-bit file gets played. It gets your attention and you don’t want to do anything else but relax and enjoy the music!
If anyone wants to order one of these, I suggest you order it online direct from Mytek. You get the newest model with the updated HW tweaks and firmware, and the waiting period isn't long. Shipping varies from a few days to a couple of weeks.
I got one a few months ago and am very happy with it. There are some amazing sounding DSD files out there. But it sounds great with PCM also. Just bought some of the Blue Note re-issues from HDTracks in hi-res, and the playback really got my feet tapping.
I'm not saying it is the best DAC out there. But I think it is as good as anything up to about twice its price. Basically, you have to get a 4K or 5K DAC to beat it. And when you add in the feature set (DSD, preamp function with analogue in, all the types of inputs and outputs you could want), it is a real bargain.
And I’m still working some kinks out. I know the non-DSD side lash-up is correct. Whatever Foobar says the file is (44.1, 88, 96, 192) is what the Mytek says it is. I need to read the ‘manual’ and figure out how to make the display stay lit. I also need to figure out the DSD side. When playing DSD files from my external hard drive, the Mytek doesn’t show ‘DSD’ on the display. It just shows ’88.’
If the Mytek gets any better, it would be scary. Once I get the DSD and the display lined out, the next step will be to switch over to XLR cables from the RCAs.
