Same ticket gets you admitted to both campsThe use of my iPod Touch as a graphic, fully-interactive remote control alone is worth the price of admission!
Not quite Steve. Having to wake up the unit to control something takes too long -- much longer than picking up a remote and using it. Until OS 4.0 comes to the Mac with multi-tasking ability to let multiple things run without losing their network connection, it is not suitable for simple things like changing volume or TV channels. For scenarios that could take longer, such as searching for what to play, it is a fine choice. But for interactive stuff, it is not.IMHO the ipad makes for the best controller
Same ticket gets you admitted to both camps. Software exists for iTouch/iPad/iPhone to control PC apps just the same. Here is a version for J River: http://melloware.com/products/rivermote/
Your other points were mostly addressed by others. I will just add one more: the fear of putting together a PC in a thread where we are discussing how to put together a music server seems odd to me. Either you are afraid of computers or you are not. If you are afraid, then you should get a black box music server such as Meridian's Soolos. Putting together a PC these days is dead simple. If you played with legos when you were little, you can do the same with a PC. The motherboard has every peripheral you can think of. So there is nothing to plug-in. Get an Intel board and you are assured of high-quality drivers, most if not all of which is in Win7 install disc. Places like Newegg.com will sell you complete kit if you don't want to figure out which memory and CPU go together. The rest is just plugging in a Sata and power cable and you are golden.
Putting together a PC will teach you a lot about what is under the hood and what it can or cannot do. Forums like this can walk you through it the first time. Once there, the sense of accomplishment is quite high -- quite a bit higher than buying a shrink-wrapped Mac. On that topic, let's not pretend that the only way to get a Windows PC is to build one. Units from HP and Dell come prebuilt and pretested and if you get the versions without bloatware, then you are good to go without learning a thing. Turn them on and the thing works. Their extensive build to order process lets you customize your PC to a huge extent.
The problem usually lies in the routers in your example. They take a reference design by the chip manufacturer and spit them out as fast as they possibly can with very little testing. Yet if anything needs testing for a long time, it is a network device. As an aside, those routers most run Linux, cousin of the Mach Unix where OSX came from.
I'm sure you're right. The point is this stuff doesn't happen in the Apple world, or at least it hasn't happened to me. And when you have Apple computer + Apple router = perfect integration. That horrible closed system thing.![]()
P
Hi
Let's not drift too much toward router ... Yet I would say that for such Apple is not your friend .. D-Link , Linksys and Netgear are.. With D-Link a solid and somewhat under-appreciated performer.
Let's re-center toward the Apple vs Windows debate... where I think for once one would be wise to stick to Windoze , specially W7 ... There are out there a plethora of Media player... No don't use Windows Media Player .. NOt worth it
Use rather
Media Monkey ( free) or Foobar but I am repeating myself ... I am willing to try JRC... I cannot really see what it will bring to my table since I already have bit-perfect through foobar ...
ANother question .. Why Amarra ? Does it really sound better ? I can't see why it should and so far I hear no differences between Media Monkey and Foobar on the Windows PC....
Use rather
Some audiophiles see PC based audio as just a way to get better sound quality - a change of transport.
In my case, using more than the lowest common denominator tags was important. Most of music collection is classical music and other genres where both Composer and Performer are important. I tried a number of player programs over a period of months to develop a thorough understanding of what I wanted and to find software that would deliver what I wanted.
Does Amarra running on top of itunes allow for HiRez files
iTunes supports composer and artist. Same thing. I think the choice of Apple vs PC should have to do with the operating system, the human interface, the available software, etc
"etc" should also include the infinite range of hardware that is available to Windows PC users.I think the choice of Apple vs PC should have to do with the operating system, the human interface, the available software, etc.
That's true although until recently, you couldn't easily build a platform that was cool and quiet because of the high power consumption of the CPU even when doing nothing.It should be about the computer. Music playback is not a demanding function for contemporary computer. It's not even close. Even an outdated Mac or PC can handle it while multifunctioning quite well.
I am not following this comment. You can run iTunes on Windows. If that is the sole function of this music server (in its playback mode), what is it that is different about it when running iTunes on both? And what is hard about that difference?The functional differences between iTunes and Media Monkey are few compared to the differences between W7 and OSX.
P
A good reason. If there were any reason to believe it could improve sound quality, I'd be tempted. There's not. And I don't hear it.
P
P
And what are these differences W7 and OSX that are significant?
