There is something about having a host of resistors, capacitors and inductors (MIT's own words) in the speaker cable signal path that does not sit well with me.
Ask away...this is what i really am here for...to enjoy talking about something we're all passionate about. ALL levels...now that is not really down to just the cable. In my own personal experience (ie my own system)...what has happened due to 2 major changes...is that my entire system has become extremely low in distortion. Some great equipment choices...but also frankly some dumb luck.
I first got the Wilson X1/Grand Slamms. Then i ended up upgrading my CJ and Gryphon to the GAT and the Colosseum...as soon as that happened, i noticed i was consistently turning the volume DOWN... because i could hear everything at lower volume levels. That was the first time i have ever done this in 20+ years.
Now, of course, since this has happened, when i got the upgrade of the XL MM2 speaker cables,
i noticed these improvements at ALL volume levels... so to answer yoru question, the benefits are all there at every volume level...it is really up to the overall distortion level and noise floor of the system to allow you to hear it.
hope that is helpful.
What do the boxes on the MIT And Transparent cables actually do? I have read the marketing blah blah but from user experience do they have any real meaningful function and so what is it?
Bruce Brisson (MIT) has quite a few patents (listed on the web page) that are very interesting reading. I didn't notice any patent disclosures on Transparent's website. The most recent three patents listed for MIT describe approaches used for the 'articulation' points, which are basically phase shift correction points.-----Me too, I've read some blah-blah-blah stuff about MIT and also Transparent speaker cables!!!
Is it all Froot-Loop marketing, or Hoopla new dancing style?
...Pizzaz money making? ...What the heck is it, truly? ...Please, be sure of what it is written.
...Because I'm going to dig real deep on this (much more than what I already read). Ty :b
* Fantastic thread by the way!
The inductive character of cables tends to cause the electrical phase of the signal to shift forward as electrons move down the cable. When the phase shift leads by 45 degrees, a C, RC or RLC network is employed to bring it back to zero degrees at that point. The places where that correction is performed is referred to as 'articulation points'. The net result is that by the time the waveform gets to the speakers the resulting phase shift is far less in error than would be the case in most cables, so the overall presentation is more time-frequency coherent and that goes along with their claims of recovered dimensionality and depth of the soundstage. Those are among the first things to go when phase alignment isn't maintained. Of course, if your speakers aren't phase coherent (time aligned) in the first place the effect won't be as dramatic.
I assume you are referring to this patent http://www.freepatentsonline.com/6658119.html - I've read this years ago, and what MIT is really missing in my book is that this extreme 45-degree shift occurs in extremely high frequencies, not the audio band, so I question any value or effect in what we hear. Moreover, if you combine this with "energy storage" claims as per http://www.freepatentsonline.com/5956410.html (the use of a capacitive network placed between the positive and negative conductors of audio signal transmission line and/or an inductive network placed in series or parallel with the positive and/or negative conductor of an audio signal transmission line, to significantly reduce or eliminate audible pre-emphasis created by non-uniform storage of energy within the line) the door is open to smearing (non-uniform storage in a cable??!?!?!). Finally, I am not convinced that even a "noise suppression" network as per http://www.freepatentsonline.com/4954787.html has non detrimental effects - cables can suppress external noise with advanced construction techniques, not networks.
What's worse, they give you the choice to switch between numbers of "articulation poles" for high def in some cables, as if you'd want anything but what you paid for; and the shear number of these "articulation poles" - or base frequencies of presumed phase corrections - indicates they are not only in the high frequencies where some very small phase shift may occur, but up and down the spectrum. I avoid MIT like the plague. I really hope MIT would jump in here and correct my views as misinformed.
---See! That's what's interesting here. ... Science between written words and listened sounds. :b
"Whose truth, whose lies?" - Doug MacLeod
Haha...true! But at least I've heard the things![]()
-----Yeah but how's your hearing?![]()
True again haha ! My hearing is typical for a 51 year-old manSame ears listening to several brands and STILL choosing MIT
And again: at least I HAVE heard the things. Dissing something without knowing it first-hand is....eh....shall I say it ..... nah.. I won't
-----Anything passed 40 I wouldn't put too much weight on.
Please don't, 'cause the dealer carries them and I heard them numerous times.
---...66? ....................... :b
As far as I can see, the only patents specifically dealing with articulation in my context are 5956410, 6658119 and 7242780.I assume you are referring to this patent http://www.freepatentsonline.com/6658119.html - I've read this years ago, and what MIT is really missing in my book is that this extreme 45-degree shift occurs in extremely high frequencies, not the audio band, so I question any value or effect in what we hear. Moreover, if you combine this with "energy storage" claims as per http://www.freepatentsonline.com/5956410.html (the use of a capacitive network placed between the positive and negative conductors of audio signal transmission line and/or an inductive network placed in series or parallel with the positive and/or negative conductor of an audio signal transmission line, to significantly reduce or eliminate audible pre-emphasis created by non-uniform storage of energy within the line) the door is open to smearing (non-uniform storage in a cable??!?!?!). Finally, I am not convinced that even a "noise suppression" network as per http://www.freepatentsonline.com/4954787.html has non detrimental effects - cables can suppress external noise with advanced construction techniques, not networks.
In the patents they list example frequencies which have been measured that are within the audio spectrum. Inductance is Inductance. There's no reason that I know of why it wouldn't affect all frequencies, depending on the degree and Q of the cables being tested.What's worse, they give you the choice to switch between numbers of "articulation poles" for high def in some cables, as if you'd want anything but what you paid for; and the shear number of these "articulation poles" - or base frequencies of presumed phase corrections - indicates they are not only in the high frequencies where some very small phase shift may occur, but up and down the spectrum. I avoid MIT like the plague. I really hope MIT would jump in here and correct my views as misinformed.
Hi Ack,
in your own Spectral amp set?
Cheers Wim
